Can anyone advise me on how to use the weather integration? I’m trying to set up a simple automation that will speak a simple local weather forecast but, as often with HA, I’m lost. Because the documentation doesn’t include any "how to"s, I’ve managed to add the integration and start to create the automation but am then clueless on how to output the forecast.
When setting up the integration I entered the API key from OpenWeatherMap The documentation says “There is currently support for the following device types within Home Assistant: * Sensor * Weather” but I saw only sensor, the device I don’t want.
I don’t understand what “device” or “area” mean in this context. Is this the device to output the forecast or a sensor that will read the temperature, humidity etc (which I don’t have)? In the context of weather forecasting I would expect area to be my geographical area, but HA is only asking me to enter an area within my house and I can’t see where or how to specify which geographical area forecast is wanted. Presumably I need to add some fields from the forecast structure that OpenWeatherMap returns, but can only see a list of conditions and no way to get a summary, or any other examples of how to use them.
When deleting the integration and adding it again I see the following at the point where I would expect to have to specify the weather device - why does HA ask only for an area?
From the docs: “Devices are a logical grouping for one or more entities.” A device may represent a physical device which can have one or more sensors or it may just be a collection of entities provided by a single integration without a physical object.
HA only asks for an area because there are no other user-configurable inputs, everything else is handled by the integration based on the latitude and longitude you already provided. You do not need to assign an Area, it is optional.
By calling the weather.get_forecasts service in the Developer tools > Service tool you can get a YAML representation of the response data. You will need to use Templates to parse and output the desired information.
alias: Weather
description: ""
- platform: conversation
command:
- What's the weather forecast
condition: []
- service: weather.get_forecasts
type: daily
entity_id: weather.openweathermap
response_variable: w
- service: tts.speak
cache: true
media_player_entity_id: media_player.all
message: |-
{% set next = w['weather.openweathermap'].forecast[0] %}
The forecast for today is
{{ next.temperature}} degrees and {{ next.condition }} with a
{{ next.precipitation_probability }} percent chance of precipitation.
mode: single
For anyone setting up custom sentences and intent scripts
custom_sentences/en/
language: en
intents:
CustomGetWeather:
- sentences:
- "(what is | what's | whats) {ord_day} local weather"
- "(what is | what's | whats) the local weather"
- "(what is | what's | whats) the local weather {ord_day}"
- "{ord_day} weather report"
lists:
ord_day:
values:
- "today's"
- "todays"
- "tomorrow's"
- "tomorrows"
configuration.yaml
intent_script:
CustomGetWeather:
type: daily
- stop: ""
speech:
text: |
{% set day = 1 if (ord_day is search('tomorrow') or now().hour > 21) else 0 %}
{% set next = action_response['weather.openweathermap'].forecast[day] %}
The forecast for {{ 'tomorrow' if day else 'today'}} is high of
2024-08-05 EDIT: Updated to show use of weather.get_forecasts service call.
Thanks for this! Got it working using AccuWeather since the OpenWeatherMap API is doing all the crazy error stuff lately. I only had to make one adjustment to the configuration.yml piece:
intent_script:
CustomGetWeather:
type: daily
entity_id: weather.home
- stop: ""
speech:
text: |
{% set next = action_response['weather.home'].forecast[day] %}
When I switched the service to weather.get_forecasts …with an “s” at the end since the weather.get_forecast is now deprecated, the speech does not work anymore. I noticed that when you call the service in developer mode, there is an extra “weather.home” before the “forecast” starts underneath it, if you understand me. I believe the {% set next = w.forecast[0] %} needs to incorporate the “weather.home” somehow, but I do not know how to do this.
Also, the precipitation_probability does not seem to exist as it does not give a value.
Since the weather.get_forecasts service has the ability to return forecasts from multiple weather integrations you need to specify the calendar you want to retrieve values from:
alias: Weather
description: ""
command:
condition: []
type: daily
cache: true
message: |-
mode: single
Instead of send this to a media_player, you could also give it to the Voice Assistant (via Intent Script). When you set a custom_sentence “what is the weather today”, you can return the spoken weather as an answer:
Here is my intent_script:
CustomWeatherToday:
- action: weather.get_forecasts
type: daily
entity_id: weather.your_weather_entity
- stop: "Return value to intent script"
speech:
text: >-
{% set next = action_response['weather.your_weather_entity'].forecast[0] %}
The weather forecast for today is
{{ next.condition }} at {{ next.temperature | round(0) }} degrees and
{{ next.precipitation | round(0) }} milimeters of rain.
The use of a media player group as the target was part of the original post.
FWIW, I did include a custom sentence and intent script at the end of my original response to OP in Post #2. The sentence/script pair I posted is actually what I use, so it’s a little bit of a different approach to OP’s.
assume I’m trying to override the built-in HassGetWeather, as I can’t for the life of me make a custom sentence “What is the weather today” work [it just tells me “Sorry, I am not aware of any device called weather today”]
I can get it to partially work like this:
responses:
intents:
HassGetWeather:
default: >-
The current weather is {{ state.attributes.get('temperature') }} and {{ (state.state | string).lower() }}.
but no arrangement has made the call to the action and the action_response variable work.
This is the best I’ve managed to think of, but no luck.
placing this file under custom_sentences/en
intents:
HassGetWeather:
type: daily
entity_id: weather.forecast_cedar_shores
response_variable: action_response
- stop: "return value to intent script"
responses:
intents:
HassGetWeather:
default: >-
{% set next = action_response['weather.forecast_cedar_shores'].forecast[day] %}
The forecast for {{ 'tomorrow' if day else 'today'}} calls for a high of
I’ve tried a lot of different variants, but there’s just something I’m missing here.
I’m on my mobile so cant juggle around too much.
In the custom_sentences folder, you only have the “commands”.
The magic (response) to these sentences is to be placed in intent_script.yaml
Check the documentation, its mentioned there too with examples.
