I can create a notification that announces that a device_tracker has arrived at a location, but I’d really like to be able to notify someone when a device_tracker leaves a location with the name of the location they’re leaving.
“iPhone just left the Apple Store” for example.
Is there a way to hold the previous location as a variable or report it as a zone is changed?
All 3 values are inserted into 3 columns of a Google Spreadsheet on a new row every time the script is run.
The first value identifies the {{ states.device_tracker.jons_iphone_7.attributes.friendly_name }}. I’d like the 2nd value to be the “from_state” of the device, but I can’t figure out what the syntax is for the value2 field in the automation.
