I’m hacking together this old fan to be esphome controlled but I’m stuck at the lambda actions for the output component that sets the fan speed. I can’t seem to map the output template to the correct relay states. And Im hoping some of you lambda wizards can point me in the right direction.
The fan speed is set by activating one of 3 interlocked relays. When the fan is off then all the relays need to turn off. Right now the relays are not switching correctly when I change the fan speed or oscillation.
Any thoughts on how to fix this?
This is the relevent YAML lines for the fan:
switch:
- platform: gpio
pin: 23
restore_mode: ALWAYS_OFF
inverted: true
internal: false
- platform: gpio
name: "Fan Speed 1"
pin: 25
inverted: true
interlock: &interlock_group [fan_speed_1, fan_speed_2, fan_speed_3,]
interlock_wait_time: 1s
internal: false
- platform: gpio
name: "Fan Speed 2"
pin: 26
inverted: true
interlock: *interlock_group
internal: false
- platform: gpio
name: "Fan Speed 3"
pin: 27
inverted: true
internal: false
fan:
- platform: speed
output: fan_speed_output
oscillation_output: oscillation_output
speed_count: 3
output:
type: binary
write_action:
- if:
condition:
lambda: return (state = 1);
then:
- switch.turn_on: oscillation_switch
- if:
condition:
lambda: return (state = 0);
then:
- switch.turn_off: oscillation_switch
type: float
write_action:
- if:
condition:
lambda: return (state = 0.33);
then:
- switch.turn_on: fan_speed_1
- if:
condition:
lambda: return (state = 0.66);
then:
- switch.turn_on: fan_speed_2
- if:
condition:
then:
- switch.turn_on: fan_speed_3
- if:
condition:
then:
- switch.turn_off: fan_speed_1
- switch.turn_off: fan_speed_2
- switch.turn_off: fan_speed_3
