Ovekiz integration in home assistant : invalid authentification
I’m using home assistant, and I have connected my Atlantic device using Overkiz. It was working until recently.
But now, Overkiz says “invalid authentification”. So that I cannot access to information of my atlantic device anymore.
I have tried to redefined a new password from the cozytouch application. It works. I can be connected from the apps, and the user/password is ok.
Could you help me ?
thank you
I finally found the problem. I had to update my version of Home Assistant.
It seems obvious, but as the update section of Home Assistant says there is no update, I trusted it.
Hope this could help other meeting the same issue.
