Over Omnik Omvormer
Mijn omvormer staat op Waiting 0S
hoe kan ik dat verhelpen.
Ik heb alles al geprobeerd ( Resetten , stroom eraf gehaald )
maar niks werkt.
Firmware upgrade misschien ? maar hoe en waar kan ik deze vinden.
mvg Mathijs
Hi Mathijs,
did you fix “Waiting 0s” issue ?
BR,
Majo
Majo,
I know its probably not needed anymore but might be helpful for others.
This problem can Be fixed with an update of the inverter. For that you need a specific pcb that goes into the slot of the wifi card. This loads firmware into the inverter.
Hi all, I don’t know if someone still need an inverter fixed. But I have found a work around for this problem. It is not something that you can fix by your self but I can help you with it. If you are interested you can send me a PM.
Hi, is this interface anywhere to be found? Seems that it is not. Best regards, Paul
