1x Somfy Tahoma Box V.2
2x Somfy Sunea IO Motor for Curtains Sunglasses
3x Somfy RTS Micro Receiver for Roller Shutters
Any chance?
Any chance?
Sadly these devices are not yet supported. But have a try with the Tahoma component. You can keep my component enable, so when your devices will be detected in later update you will see them.
Iām starting to be a bit jealousā¦ Itās still not working here, and Somfy is not answering my emails anymoreā¦
Same here, Somfy assistance, after the first automatic e-mail, has not responded to me.
Hereās the 500:
Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/app/homeassistant/components/http/real_ip.py", line 33, in real_ip_middleware
File "/usr/src/app/homeassistant/components/http/ban.py", line 67, in ban_middleware
File "/usr/src/app/homeassistant/components/http/auth.py", line 216, in auth_middleware
File "/usr/src/app/homeassistant/components/http/view.py", line 115, in handle
result = await result
File "/usr/src/app/homeassistant/components/config/config_entries.py", line 145, in get
return await super().get(request, flow_id)
File "/usr/src/app/homeassistant/helpers/data_entry_flow.py", line 74, in get
result = await self._flow_mgr.async_configure(flow_id)
File "/usr/src/app/homeassistant/data_entry_flow.py", line 87, in async_configure
flow, cur_step['step_id'], user_input)
File "/usr/src/app/homeassistant/data_entry_flow.py", line 123, in _async_handle_step
result = await getattr(flow, method)(user_input) # type: Dict
File "/usr/src/app/homeassistant/components/somfy/config_flow.py", line 103, in async_step_creation
code)
File "/usr/local/lib/python3.7/site-packages/pymfy/api/somfy_api.py", line 54, in request_token
client_secret=self.client_secret)
File "/usr/local/lib/python3.7/site-packages/requests_oauthlib/oauth2_session.py", line 307, in fetch_token
self._client.parse_request_body_response(r.text, scope=self.scope)
File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/clients/base.py", line 415, in parse_request_body_response
self.token = parse_token_response(body, scope=scope)
File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/parameters.py", line 425, in parse_token_response
validate_token_parameters(params)
File "/usr/local/lib/python3.7/site-packages/oauthlib/oauth2/rfc6749/parameters.py", line 435, in validate_token_parameters
raise MissingTokenError(description="Missing access token parameter.")
oauthlib.oauth2.rfc6749.errors.MissingTokenError: (missing_token) Missing access token parameter.
I am having the same message āan error has occurred, please try again laterā
I send an email to somfy but no response so far. Anyone managed to get past this error?
Iāve exactly the same error on my server. I think this is related to Somfy again. We will see if they solve the issue by themself.
Thanks for the update!
Iām using this for quit a few weeks and today suddenly all my covers are gone in Hass. They are not available. ? How can this happen.
Hi All,
I had the same callback issues beforeā¦
Then after emptying cache/history of my firefox browser it all went ok!
Due to this I had to re login with Somfy.
accept the connection and then it all was ok!
Thanks for the tricks! I hope it will help some other guys.
On my side to solve my Token expired error, I removed the Somfy integration and then added it again. Thatās the first time I have to do this since the beginning of this component.
Iāve an idea of fix to remove the ugly stack trace in the log and handle in a better way such token error.
Does this means that you passed this ugly error (sorry for the message in French)?
I have removed the Somfy app, added a new one and updated credentials multiple times during the passed few days, nothing helped. And of course no answer from Somfyā¦
Yes, luckily it was ok for me. Just a shame to see this issue occur since so many time.
Did you tried to reset your cache browser as suggested by @Rosiaantje?
@vlebourl, I had exactly the same thing happeningā¦ like mentioned way back in this topic and as far as I could understand itās more or less an activation triangle between your HA, your browser (probably on an other IP in same subnet) and the servers of Somfy. again clearing history/browser cache and then tying to activate it again in HA did the trick for me.
Hi there,
Iām following koomik tuto, and I have an issue when restarting HA.
First, āsomfy-open-apiā branch doesnāt exist anymore on tetienne HA repo, so I took files from dev branch.
But when restarting :
2019-07-19 10:47:59 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for somfy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-07-19 10:48:21 ERROR (MainThread) [homeassistant.config_entries] Config flow is not supported for custom integration somfy
2019-07-19 10:48:24 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/data_entry_flow.py", line 64, in async_init
handler, context=context, data=data)
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/config_entries.py", line 562, in _async_create_flow
raise data_entry_flow.UnknownHandler
homeassistant.data_entry_flow.UnknownHandler
Any idea ?
You donāt need anymore to use the custom component. This one is now official. So you can remove the custom component, keep your configuration and restart HA.
Oh, I didnāt know, thanks. Now, itās better, but I have the same issue after trying to configure integration :
"Une erreur est survenue Veuillez rĆ©essayer. Si le problĆØme persiste, veuillez contacter le support technique.
I tried on a different browser, but nothing helpedā¦
Hello tetienne,
somfy stop working to me, but in log is nothing about somfy.
Any idea?
On my side I got error 404 when the command is send. Itās like their server is down, and our device not recognizeā¦ Thatās a new one, hurray!
