You are welcome!
so in your case, if you donât see any devices listed it can mean two things: your devices are not yet supported or your country is not eligible.
Is there a list of supported devices and/or countries? I have a Connexoon setup, running in New Zealand. Theyâve traditionally had a different setup for Australia and New Zealand, though I was hoping the Open API would change this.
Your stacktrace is not linked to my component but seems related to the Tahoma component which use the unofficial API. Itâs interesting to see even this has some trouble.
Here you can see the list of supported devices: https://developer.somfy.com/products-services-informations
For the countries, I donât have the information. Would be nice to have it, so I can update the component documentation page.
Thanks @tetienne. Somfy Oceania Support had this to say:
Hello Michael,
Currently the Open API via developer.somfy.com for this region is not available.
There is no official ETA when this will be made available.
Regards,
Somfy P/L Tech Support
So that clears that up. Guess Iâll have to go back to try reverse engineering the Australian Connexoon app. Itâs not too different to the Tahoma component, but uses different servers and somewhat infuriatingly ever so slightly different syntax.
I still have the error âUne erreur est survenue Veuillez rĂŠessayer. Si le problème persiste, veuillez contacter le support technique.â when trying to configure integrationâŚ
Still not working here after trying various URLs, restarting HA etc.
@tetienne what is setting the redirect_uri query parameter when I click in HA to configure Somfy? If I change the Callback URL in the Somfy app this doesnât seem to change.
Alec you can use local IP (with port) your HA. That IP use only for redirect back to HA after auth proces. You have another problem what can fix only support Somfy i think. Send them message and you hope they are write you back. :-/ Helps me write to my local Somfy and tell them about problem too, they can write to support in france too.
Nope I can remove the Somfy intergration and reconnect again without problems but it still doesnt load my devices. So the API is still having problems.
Iâm in France as well and I couldnât get it to work despite trying every combinations of restarting HA, Hassio, changing the somfy app, etc.
I wrote to somfy several times, but they donât answer⌠wait and hope I guess.
