I have a proof of concept working with Overkiz in core, now we just need to polish the code over the next months and I will have a look if we can support jailbroken Connexoon as well!
I know it’s been a while, but today I was forced to change from somf to overkiz and it comes to me much faster. Does this integration work outside the cloud, directly over the LAN?
I have an issue where it seems to time out after 24hrs etc. It works fine and accepts my password and I can see and control the entities, but after approx 24hrs the Integration says attention and no longer works, I re-enter my somfy password and it goes back to a working state. Obviously having to manually do this every 24hrs makes this unusable. I am connecting to the Oceania region, any ideas?
Check your logs and see how often its polling. I’m having issues with a bug that makes it poll once per minute, and I’m getting banned constantly. The ban at this stage has only been as much as half hour, but its enough to trigger the reauth once a day (like what you are having). I am also Oceania.
Thats just the failed auth error itself, I get these every ~60 seconds,
2022-05-05 13:19:33 INFO (MainThread) [backoff] Backing off fetch_events(...) for 0.0s (pyoverkiz.exceptions.NotAuthenticatedException: Not authenticated)
Yes, local support was already there but still had a critical bug. This bug has been fixed and we can now start to integrate this.
However, our time is currently quite limited, thus it can take a while. There is a very early alpha version available on GitHub (GitHub - iMicknl/home-assistant-core at overkiz/local_support), however this will require knowledge how to run a core development instance.
Thanks for the reply, I will have a look at the alpha, however, I probably rather wait until you implemented it. I am not that good in HA.
So take your time, as long as I know it’s in the pipeline, I am happy. I‘ll be patient, I am happy that there are people out there doing all this coding
Yes this is huge, as I’m building a new house with Somfy IO blinds and a Thermia Kalibra heathpump that uses Danfos icon thermostats The Somfy TaHoma® DIN-Rail should be perfect to combine this into home assistant with a local api in the future.
Let me know if i’m making wrong assumptions and keep up to good work!
Very nice to see this development for local api. Does this still require jailbreaking the connexoon? Or can you simply use latest orginal firmware for local access?
What you want is called optimistic mode. We don’t and will not support it as it’s a feature of the cover template. You can also enable the hidden entity named Target Closure which is the last asked position.
I don’t know if it can help. But I have installed a zigbee door sensor on every Somfy RTS cover that I have, then I created a cover template so that I know exactly the state open/close.
Of course, I can’t know the position.
