Hi, I switched to local access and it works but is there a way to completely disable or remove Somfy cloud access?
When I use the official app (TaHoma) and when Iām not connected with my wifi network itās still functioning like before. Yes I could remove the app, but the somfy box/hub still doing something with the cloud I guess (updates?)
To use ālocalā you still need an access token that is being checked with Somfy servers first. So, basically the Tahoma will always first communicate with Somfy services. And yes, it needs the (firmware) updates as well.
Thank you for your work on the integration!
I recently bought the Tahoma switch, installed the app and managed to get my sunscreen and two rolling shutters connected.
I followed the steps in the link provided when switching on the developer mode and made the connection in HA with the Overkiz integration on local API.
I had to change the IP and restart the Tahoma switch (replaced my router), but it never came up again.
When I try to make the connection again, I get a message āFailed to connectā.
The switch is working and pingable, DNS records are correct, I can connect it via cloud api so the switch is working and connected. Alse my Somfy login is working, so the credentials are ok.
I canāt find any attempt to connect in de HA logging.
Does anyone have any idea where to look? Itās all working with the cloud api, so I can rule out most of the components.
Does anyone know why I have to go through the steps with REST api to generate a token when I donāt seem to need any when connecting with the Overkiz integration?
