Unless the helper condition is the issue? If I check the state in dev tools, it’s currently set to open. But hitting the close button on the template does nothing.
Hi, thanks for the work on the local API, it is working great! As an unexpected bonus for me, I can now control my Somfy Elixo 500 3s io gate, which was not possible neither by using Homekit integration or cloud API (I thought this might be helpful for anyone searching in the forum for how to get a gate working).
Now I’d like to switch from using the Tahoma app for scenarios to Home Assistant, but I still miss one functionality for controlling venetian blinds - to do that comfortably, I need to set the position and tilt at the same time (pyoverkizalready supports that, I successfully tested it).
I have moved back to the Overkiz Local API again, now with IP-address and disabled SSL check to prevent any mDNS issues.
So far it’s been stable since moving last night, will let you know if it stays connected properly now.
I had created a solution for ‘stateful’ scenes before in HA with Input Boolean Helpers so I have four presets for my curtains and shutters and use the ‘My’ button for the RTS curtains, which is triggered with Automations when the Input Boolean is turned on.
Is here an easy way to move an existing cloud API config/integration to the local API? Or do I have to remove it completely and create a new integration?
I just deleted the cloud one and re-added the local one. I didnt have to do much more, all the new entities took up their old name, so I didn’t need to modify any of my automations.
Hope this is still on topic, but does this also work with the IO verrsion?
I’m looking to buy 4 rollershades and looking to control these via automations locally?
I have the following problem with the local API to control my Tahoma Switch.
I used the cloud API for a while and wanted to switch to the (now a core feature) local API.
I got the PIN-Code, Tahome Switch is in Dev Mode, credentials are correct (tested on somfy webpage). But is neither working for the .local nor the IP (with SSL off) way?!
For each scenario a get a “Connection failed” message without any further information.
What am I missing? I really appreciate your work and help here!!!
This is now resolved for unknown reason. Altough, I had issues with my garage door as well when using a Somfy KeyGo IO. Opening the door would change the state correctly to open(ing) but after it was open and I used my KeyGo again, the door is closing but the state kept for ~1 hour on open, which as of cource incorrect. I fixed this by using an Ikea Parasoll. When the state of the parasoll changed from open to closed, I’m calling my local Somfy API to close the door so it changes the state to closed.
I’m using The Overkiz integration for my garage door and Awning cover. I’m also using the Homekit bridge function so I see these devices in my Apple Home. For some reason, the Awning cover is seen as ‘open’ , but it’s closed. My garage door has the correct status , closed if it’s closed.
Does anyone know if this is a issue with the overkiz implementation, or the homekit bridge integration?
