Tahoma switch added via the somfy app - all seems good.
Using the integration just get “invalid authentication”. Have tried the gateway pin and local HA IP address. Password/User are correct.
Enabled developer mode on switch and am choosing local IP control.
Probably missing something simple - but any help appreciated.
similar issue here. I’ve read through all GitHub documentation and other resources like the forums here. Here’s my synopsis: Tahoma Switch working without issue on Somfy App. Developer mode activated properly. A few months and a few HA updates ago the overkiz integration both local and cloud worked flawlessly. Now for a few weeks going the integration has failed, so I removed it and try reinstalling. on the credentials popup I have tried both local and cloud and with both options I get Invalid Authentication. I am using the same credentials I always had without issue. Any ideas for a solution?
