I really love the Somfy / Tahoma developer Overkiz integration, I could finally manage to open/close my terrace roof and zip screen via Home Assistant, using node red as controlled from KNX.
What I still couldn’t get work are following:
How can I stop a cover via Node Red? the integration in dashboard works fine, but need it in Nod Red to control via KNX
How can I go to the MY-Position for cover via Node Red? the integration in dashboard works fine, but need it in Nod Red to control via KNX
How can I read the current percentage position, it’s showing up in Tahoma App, would be great to have this in KNX.
Devices with ‘my position’ have buttons, so button:press
I don’t have devices with position, but io devices (not RTS) should return values, as entity sensors.
Basically, if you can see it in HA as a sensor, you can read it (current state in NR). If it is a button, you can press it (service call on NR). If it is a cover, you can open it, close it, and stop it.
Actually no more error, was maybe another thing that totally stopped everything working. good now, but no matter what I try this button doesn’t work. Can I test if the selected button would work at all? like right click test?
In my integration with RTS blinds, they are added as covers. In HA covers are shown specially on the dashboard with ‘buttons’ for open, stop, and close. However to make the cover open, stop or close requires a service call. HA does this from the dashboard, otherwise you call the cover:open service. Same from Node-RED, it is a service call to domain ‘cover’
Glad to hear that you found the percentage sensor. Many integrations add less used entities as disabled. Sorry, but I know nothing about KNX GA, so perhaps someone else can help you.
As a general guide, the HA websocket nodes - current state - can be used to read the state value of any HA entity.
