Hi! When i woke up today my entire hass.io system is no longer working. Not sure what happened but the only error I get when plugging into HDMI is:
I tried running ha su repair
but get the error “cannot connect to container”
I have a pi 3B+
I have a pi 3B+
Bad SD card?
Look like cannot find some data so I presume maybe having trouble reading from card
The SD card is about 1 month old, and has always worked fine. Seems an update installed and broke something?
Maybe backup(copy) config files for HA and try new install to recover HA
I have same issue from yestarday.
Problem has started after very short power break. Its a second time for ,me during two months (First time was with diffrent error). Ehhh, again new installation…
I have the same problem. have you solved it?
