I was wondering if there’s a way to overlay sensor values onto webcam images? For example, I’m using IPCamviewer to display kids room webcams. Can I overlay my mqtt sensors on top of these images somehow?
I’ve set up motioneye and with an automation I add a overlay to the camera.
Then in tinycampro I can see the temp overlayed.
Thanks. I am using Motion for one of the cameras. How did you add the automation to add the overlay to the camera? Is that part of Motion, or is it a home assistant thing?
shell command:
shell_command:
cam_update: >-
curl http://10.0.1.59:7999/{{cam_id}}/config/set?text_left="{{cam_text}}"
automation:
alias: update camera 1 temp
- platform: time
minutes: '/2'
seconds: 50
service: shell_command.cam_update
data_template:
cam_text: >-
Temp:{{ states("sensor.temperature_2") | round(0) }}c
cam_id: 1
You need to allow access to the motion api port in the motion config file.
webcontrol_html_output on
webcontrol_port 7999
setup_mode off
webcontrol_parms 2
webcontrol_localhost off
Lovelace UI allows overlay
