Override all DoNotDisturb modes when alarm triggers. Also repeat
I’m using Hassio with android app, and to manage alarms I use Alarmo addon.
I have two concerns with this app and I don’t know if there is also android misconfiguration involved.
The thing is:
-when alarm triggers it sounds once like a normal notification, I will like some repeated tone until disarmed.
-alarm is muted when Do Not Disturb / Night mode is on. I managed to put hassio app into android DND exceptions, but nothing changes.
There is any way to override all possible android status and play louder alarm? Right now i think that the only think I can do is to send a Call to my phone using some external service instead notification.
you need to adjust the notification channel settings to allow for DND override, go to Configuration > Companion App > Notification Channels and then make sure the General channel (or the one you setup) has DND override permissions
you can create your own notification channel for the alarms so notificaitons like your laundry still respect DND
Same needs here.
