I have a time action switch, it switches my stereo, TV etc off when we go to bed. Most of the times we go to bed before 00:00 so the switch is set to switch off if that moment arrives. Occasionaly we stay up…later than that hour. I would like to have an override switch that tells HA not to to that action if i flipped the switch.
If anyone could give me a clue of what function to use…?
This is the automation i have now:
- alias: 'Neo Switch on'
platform: time
# When 'at' is used, you cannot also match on hour, minute, seconds.
# Military time format.
at: '16:30:00'
- service: switch.turn_on
entity_id: switch.neo_coolcam_power_plug_12a_switch_5
- alias: 'Neo Switch off'
platform: time
at: '00:00:00'
- service: switch.turn_off
Turn off the 'Neo Switch off' automation in the front end. Every automation that is not hidden has an enable/disable toggle switch.
You could write another automation to re-enable the 'Neo Switch off' automation at sunrise.
I’m waiting for a strain gauge sensor to arrive to actually detect if I’m in bed. Detecting if you are actually in bed would be a better solution for you too.
For these cases I am using an input_boolean and checking the value of the input_boolean as a condition on my automation. Your automation would then look like this:
Not really any if you are using it for one automation. If it concerns only one automation I’d probably go with the automation switch built-in, but for example with a vacation mode there are multiple automations I’d like to stay on which is why I like the input boolean better for those cases.
