I’d like to add to all my light switches the switch.flux_update
call to make sure the color is instantly set to the right one whenever I turn on a light.
The problem is that to obtain the desired result, I need the transition
property set to 0
, to be instantaneous.
I don’t want to set it to 0
in configuration.yml
because doing so I will lose the transition effect during the day.
What I’d like to do is to override the transition
property only when I call the switch.flux_update
command.
Ideally the switch.flux_update
service should accept a configuration where I can define the settings to override.
How can I do?
