Overview in reverse alphabetical order after upgrading to 2023.12.3
I still use the overview a lot for accessing things. After this update all of my areas are now listed in reverse alphabetical order. Why was this changed and can I change it back?
If you watched the stream, or read the release announcement, you would be aware that you can now change the order, or even turn individual items off.
Thanks, took awhile to figure it out. When I did get there everything was in the right order I wanted (alphabetically). I went ahead and submitted that and saved. Then it restored the previous order.
Thanks!
