Hi everyone,
I’m looking for quick help to understand how I can overwrite the color on my icon with the customize_glob.yaml.
It’s working for the occupancy sensors (Apple TV and laptop) but not for the lights: Desk [wled integration] and Rainbow [nanoleaf integration].
sensor.*_occupancy:
templates:
icon_color: >
if (state === 'Ethernet') return 'rgb(34, 160, 137)';
if (state === 'Wifi') return 'rgb(34, 160, 137)';
if (state === 'Playing') return 'rgb(34, 160, 137)';
if (state === 'Home') return 'rgb(34, 160, 137)';
return 'rgb(81, 81, 81)';
light.*:
templates:
icon_color: >
if (state === 'on') return 'rgb(34, 160, 137)';
Did I’m missing something?
ingoM
2
‘Same’ here. I can change the icon, but not the color…
Did you find a solution in the meantime?
customize_glob:
"binary_sensor.d01_zimmer5_motion_*":
icon: mdi:garage
templates:
icon_color: >
if (state === 'Clear') return 'rgb(30, 160, 130)';
return 'rgb(255, 0, 0)';
lucas3d
3
Unfortunately, I didn’t find a solution
icon_color requires custom-ui install, have you done that?
next thing to note is that not all cards in HA support that, or phrased differently, custom-ui can not customize all cards in HA…
entities work fine, entity card doesnt. Ive summed them in the readme
lucas3d
5
Hi @Mariusthvdb ,
First, thanks for your reply!
I have Custom-ui: installed, version 20210528 adapted for HA 2021.6+.
I tried different cards and I have the same issue.
did you try those entities in an entities card? because that would be the test.
