Owl CM180 rfxtrx433e
Hello, I have an owl cm180 energy monitor that I’ve setup with a rfxtrx433e. Every now and then I get a Total usage stat of 0 which is throwing off my calculations for cost for the previous hour. It doesn’t reflect on the owl monitor itself, only within home assistant. Has anybody else come across this? My gut feeling is that it’s the reading from one of the other phase inputs from the transmitter (I only have 1 connected) but I only see one input in home assistant.
The total use stat is also slightly off compared to what I see on the owl monitor, if anybody has any advice on that I’d appreciate it too!
Filter on the 7th byte which is the packet counter.
packet counter.
For subtype 0x02 = ELEC3 is CM180:
Count = 0 : packet contains instant and total power
Count > 0 : packet contains only instant power (ignore total power = 0)
That makes total sense, thanks! I had noticed the count field but couldn’t find any info about it.
I created a template sensor yesterday that only updated if total usage > 0, I might change that to count now I know what it does.
Can you share me your solution?
I was a user of Domoticz and the energy monitor was very simple (with some LUA script).
Since i’m on home assistant, i have some difficulties to implement a perfect energy monitor.
I have the same hardware: owl cm180 energy monitor with a rfxtrx433e.
I have done the integration and i have tried some solution:
  1. Direct use of ELEC3, CM180 83:62 Total usage (Cumulate KWh)
  2. Convert ELEC3, CM180 83:62 Energy usage in Kwh with plateform integration
The second solution is not the perfect one because i have some time some peak
Can you help me to have a good solution?
Anyone have a solution on this to share? :slight_smile:
@Markg @b_weijenberg Would be great if you could share the/your solution please? :slight_smile:
Not the same ‘fix’ but an option for others - is take the ‘watts’ reading and use the integration sensor, to then feed the utility_meter:
If you have a sensor that provides you with power readings in Watts (uses W as unit_of_measurement ), then you can use the integration sensor to track how much energy is being spent. Take the next configuration as an example:
  - platform: integration
    source: sensor.current_power
    unit_prefix: k
    round: 2
So add the below to the end of your ‘sensor’ configuration modifying as appropriate for your own OWL device:
    source: sensor.elec3_cm180_8b_22_energy_usage
    unit_prefix: k
    round: 2
Then:
utility_meter:
  electricity_hourly_kwh:
    source: sensor.electricity_energy_spent
    cycle: hourly
  electricity_daily_kwh:
    cycle: daily
  electricity_weekly_kwh:
    cycle: weekly
  electricity_monthly_kwh:
    cycle: monthly
  electricity_quarterly_kwh:
    cycle: quarterly
  electricity_yearly_kwh:
    cycle: yearly
Define a script to easily reset your utility sensors:
utility_reset:
  sequence:
    - service: utility_meter.calibrate
        entity_id: sensor.electricity_hourly_kwh
        value: 0
        entity_id: sensor.electricity_daily_kwh
        value: 0
        entity_id: sensor.electricity_weekly_kwh
        value: 0
        entity_id: sensor.electricity_monthly_kwh
        value: 0
        entity_id: sensor.electricity_quarterly_kwh
        value: 0
        entity_id: sensor.electricity_yearly_kwh
        value: 0
Then call the ‘script.utlity_reset’ from Developer Tools.
So I think the below sets out to do what Mark discusses above - ignoring values of 0.
My CM180 died and/or stopped transmitting randomly, the newer CM180i that I have only shows amps/current and total usage in wh (no power in watts, like the CM180).
So, you need to set the below in the customize.yml as it incorrectly shows in kWh hours in HA, when the numbers are in Wh:
sensor.elec4_cm180i_5f_00_total_usage:
  unit_of_measurement: Wh
Then a template sensor, if the CM180i returns a 0 value we don’t update the template sensor value (we just return the old value), converting only non-zero values to kWh hour:
    sensors:
      electricity_usage_kwh:
        unit_of_measurement: 'kWh'
        value_template: >
          {% if states('sensor.elec4_cm180i_5f_00_total_usage') | float == 0 %}
            {{ states('sensor.electricity_usage_kwh') }}
          {% else %}
            {{ states('sensor.elec4_cm180i_5f_00_total_usage') | float / 1000 }}
          {% endif %}
Then use the template sensor to feed the utility meter:
utility_meter:
    source: sensor.electricity_usage_kwh
    cycle: hourly
    cycle: daily
    cycle: weekly
    cycle: monthly
    cycle: quarterly
    cycle: yearly
Works well with the mini-graph-card bar chart in lovelace, settting the aggregate_func to max
type: 'custom:mini-graph-card'
entities:
  - entity: sensor.electricity_hourly_kwh
    name: Electricity Usage - Hourly kWh
hours_to_show: 24
group_by: hour
aggregate_func: max
show:
  graph: bar
Where should I put the code above to make this weork? Obviously I’ll need to chage the names of the sensors, but I’m a little confused as to what yaml file this all gets added to.
customize.yml
configuration.yml
    sensors:
        value_template: >
          {% else %}
          {% endif %}
utility_meter:
  electricity_quarter_hourly_kwh:
    cycle: quarter-hourly
    cycle: hourly
    cycle: daily
    cycle: weekly
    cycle: monthly
    cycle: quarterly
    cycle: yearly
N.B. Assuming you already have a ‘sensor:’ key, don’t add it again other it will fail to load/validate - just add the ‘- platform: template’ as a new entry, nested below the others.
Lovelace, raw edit/manual add card:
entities:
hours_to_show: 24
group_by: hour
aggregate_func: max
show:
  graph: bar
With some extra gauge as well:
Full Lovelace - requires mini-graph-card to be installed.
type: vertical-stack
cards:
  - type: horizontal-stack
    title: Live Electricity Usage
    cards:
      - type: gauge
        entity: sensor.elec4_cm180i_5f_00_current_ch_1
        min: 0
        severity:
          green: 0
          yellow: 5
          red: 30
        max: 40
      - type: gauge
        entity: sensor.electricity_usage_live_w
        min: 0
        severity:
          green: 0
          yellow: 1000
          red: 1200
        max: 2000
  - type: custom:mini-graph-card
    entities:
    hours_to_show: 48
    group_by: hour
    aggregate_func: max
    show:
      graph: bar
    entities:
      - entity: sensor.electricity_daily_kwh
        name: Electricity Usage - Daily kWh
    hours_to_show: 168
    group_by: date
    aggregate_func: max
    show:
      graph: bar
    entities:
      - entity: sensor.electricity_weekly_kwh
        name: Electricity Usage - Weekly kWh
    hours_to_show: 336
    group_by: date
    aggregate_func: max
    show:
      graph: bar
    entities:
      - entity: sensor.electricity_monthly_kwh
        name: Electricity Usage - Monthly kWh
    hours_to_show: 336
    group_by: date
    aggregate_func: max
    show:
      graph: bar
