Hi There,
I have HA running as a VM on a Proxmox server.
It works great, I also have a working cloudflare tunnel with one time pin. This works to.
I installed Owntracks following this fine guide (OwnTracks - Home Assistant) I copied the encryption key and filled in the data as stated in the manual.
However my phone (Pixel7) can’t connect home…I copied some logs over…
2023-11-22 20:59:46.663 D MessageProcessor: message:failed to connect to home.mydomain.net/104.21.7.244 (port 8123) from /10.190.156.198 (port 47024) after 30000ms,
2023-11-22 20:59:46.664 E MessageProcessor: Message delivery failed. queueLength: 387, messageId: 1700682974539-a057f3
In the gui on my phone at status I see
failed to connect to mydomain.net/104.21.7.244 (port8123) from10.190.156.198 (port 47024) after 30000ms
of course mydomain isn’t the real one
the ip adresses after this domain name tend to change…
Can somebody shed a light on it
Kind regards
Guy
