Owner is Grayed out
I am the owner but all of the options a grayed out. Administrator, Local access, Allow user login. Other users don’t have this problem
The owner is like a super system administrator user.
The owner will always be an administrator. Hence you can not turn this off.
The owner always needs to be allowed to log in. Hence you can not turn this off.
Local access only - you should be able to enable/disable this setting for the owner.
