Hello everyone,
I encountered a problem with owntrack HTTP, homeassistant is reporting that i’m missing some dependicy.
Now, everhing was working correctly until last week, I’m not sure exactly if the homeassistant update broke it or something else…
Configuration in configuration.yaml is pretty simple:
- platform: owntracks_http
track_new_devices: yes
waypoints: False
This is what homeassistant is reporting in logs on startup:
2018-12-04 15:35:32 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.device_tracker.owntracks_http. Make sure all dependencies are installed
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/loader.py", line 92, in get_component
module = importlib.import_module(path)
File "/usr/lib/python3.6/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 994, in _gcd_import
File "<frozen importlib._bootstrap>", line 971, in _find_and_load
File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 678, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/device_tracker/owntracks_http.py", line 15, in <module>
from homeassistant.components.device_tracker.owntracks import ( # NOQA
ImportError: cannot import name 'PLATFORM_SCHEMA'
2018-12-04 15:35:32 ERROR (MainThread) [homeassistant.loader] Unable to find component device_tracker.owntracks_http
Just for reference, here’s a copy paste from component python file
PLATFORM_SCHEMA, REQUIREMENTS, async_handle_message, context_from_config)
I’m not sure how to fix this, I’m afraid to change something in code because in my expirience that will only lead to more trouble
Also, I didn’t find any topics with this specific problem so I’m out of ideas Please help, thank you!
