Owntrack - lets encrypt - mqtt
Hi! After update to hass.io my mqtt broker won’t work and i can’t track mobile over gps. I think it’s somthing about the ssl but what changes should i go now when i use hass.io?
I get this error messages
Failed to connect due to exception: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:841)
Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 352, in _async_add_entity
    await entity.async_added_to_hass()
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 280, in async_subscribe
    topic, msg_callback, qos, encoding)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 662, in async_subscribe
    await self._async_perform_subscription(topic, qos)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 697, in _async_perform_subscription
    _raise_on_error(result)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/mqtt/__init__.py", line 782, in _raise_on_error
    'Error talking to MQTT: {}'.format(mqtt.error_string(result_code)))
homeassistant.exceptions.HomeAssistantError: Error talking to MQTT: The client is not currently connected.
Error setting up platform owntracks
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 180, in async_setup_platform
    hass, p_config, tracker.async_see, disc_info)
  File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/owntracks.py", line 93, in async_setup_scanner
    hass, context.mqtt_topic, async_handle_mqtt_message, 1)
After adding certificate: 'auto' to my mqtt-cofig i’m back on track.
