Hey Everyone, has anyone noticed a issue with Home Assistant 0.68 & 0.68.1 that Owntracks does not auto update your location but if you manually push your location it updates. I’m having this issue on more then one phone that is running owntracks
I had similar issues a while back, ended up giving up on Owntracks after a long time using it and switching over to using Zanzito (on Android). Far superior IMO.
Does that app work on ios both devices i use are apple
I believe it is Android only. You could use the IOS Home Assistant app though for Apple devices available here
I’ve tried using that but i found it unreliable and owntracks was better.
Are you using MQTT or HTTP for Owntracks?
MQTT over SSL
Might be worth trying HTTP to see if that helps at all.
I didn’t know such an option existed how do i set it up?
Thanks I set it up last night will test it out today see how it goes.
How is it running for you now?
Maybe a little better but still having issues, I think my HASS is dieing some of my automations are firing off on there own and other just do not respond now
