so is there a way to set the manual configuration options for owntracks now? The integration in the UI doesn’t allow for any special options to be configured and now I am getting the inaccurate locations being reported by my devices because i had to remove this override. (FYI my devices have the same inaccurate location setting to 200 in the owntracks app on android)
owntracks:
max_gps_accuracy: 200
waypoints: true
FYI I am using nabu casa with the owntracks hook and it is configured via the UI in integrations. My device trackers show up as entities but when i add the configuration.yaml settings, the devices go to unavailable. I am assuming there is some kind of secondary ID getting setup or the owntracks: key is overriding the UI key somehow.
The forum gave you a big hint about not replying to a solved thread - you should listen to it, particularly as your question is unrelated to that topic.
known_devices.yaml has nothing to do with how you configure owntracks which still has the YAML configuration you listed.
My bad. Sorry about that. I haven’t posted much in this forum so I wasn’t sure the protocol.
So I am not using known_devices.yaml anymore. I configured own tracks from the UI, it was working, then I had to set up the integration again when we got new phones (I lost the hook and encryption key info) and that’s when it stopped tracking properly/wasn’t able to use the configuration.yaml to set other values.
This is what my devices do now with the owntracks configured in the yaml and the ui
Also just playing with it, i cannot just have waypoints: true either. Basically the only thing that is supported looks to be max_gps_accuracy, everything else causes the devices not not report properly.
