I used the mqtt owntracks with a script to request the device locations (background), so it was not necessary to have the owntracks application open. After updating Home Assistant to version 0.94 (Owntracks Integration - HTTP), I can only update the device locations when the owntracks application is running. How do I keep updating locations even when the owntrack application is not running?
hi, ever figured this out? do you also use http mode for changing remote config?
