Hello everybody,
I have the problem that the device trackers are not updated via Owntrack:
Owntrack runs in MQTT mode, updated data also go to the Home Assistant - however, the data is not imported into the corresponding device_tracker - as a result, the MQTT data record is up-to-date, but the associated device tracker is not.
Owntrack configuration:
# Geolocation
owntracks:
max_gps_accuracy: 200
waypoints: true
mqtt_topic: "owntracks/#"
events_only: false
waypoint_whitelist:
- xxx.xxx
- xxx.xxx
region_mapping:
zu Hause: zu Hause
Does somebody has any idea?
Best wishes
Michael
First a couple of questions:
- Any errors in the log?
- How do you see that the information get’s to Home Assistant?
Then some good old investigations tricks:
Remove every owntracks options from your configuration and just start with:
owntracks:
and see whats happens next.
If that works add one option at a time until you find the offending statement.
I’m not sure if space in the region mapping is ok or not.
Good luck!
I have created an automation that solves the problem:
## GPS-Aktualisierung Ontracks ##
- alias: 'GPS Update Michael'
- platform: mqtt
topic: owntracks/michael.xxxx/iPhone
- data_template:
dev_id: michael
gps:
- '{{ trigger.payload_json.lat }}'
- '{{ trigger.payload_json.lon }}'
gps_accuracy: '{{ trigger.payload_json.acc }}'
battery: '{{ trigger.payload_json.batt }}'
service: device_tracker.see
I have made a corresponding entry in the known_devices.yaml:
michael:
icon: mdi:map-marker
mac:
picture:
track: true
Best wishes
Michael
