Hello, I’m very new to HA and need some help with owntracks. I’ve got owntracks setup by itself but it only shows me as “away”. I feel like I have everything in the correct place (owntracks and mqtt in configurations.yaml). In the owntracks app, it says “connected”. I thought that would work but it doesn’t update me as “home” I checked the mqtt log and it looks like it connects and then dissconnects. Anybody have any ideas? Thanks
If you haven’t already, give Bens (@bruhautomation) a watch. You can change his CloudMQTT broker info to your own hosted on your Pi.
Firstly I would use an MQTT client to ensure OwnTracks is connecting and updating the topic as it should. I use MQTT Spy which is multi platform. Once connected to your MQTT server subscribe to topic # which essentially covers all topics. Send a manual update from OwnTracks and see if the data comes in.
I’m triyng to set owntracks and home assistant to work together but there is something i’m missing because i’m receiving this ERRORS in the log:
2018-01-18 20:09:12 ERROR (MainThread) [homeassistant.core] Invalid service data for mqtt.publish: Invalid MQTT topic name for dictionary value @ data['topic']. Got 'owntracks/#'
2018-01-18 20:09:13 ERROR (MainThread) [homeassistant.core] Invalid service data for mqtt.publish: Invalid MQTT topic name for dictionary value @ data['topic']. Got 'owntracks/#'
2018-01-18 20:09:14 ERROR (MainThread) [homeassistant.core] Invalid service data for mqtt.publish: Invalid MQTT topic name for dictionary value @ data['topic']. Got 'owntracks/#'
2018-01-18 20:09:15 ERROR (MainThread) [homeassistant.core] Invalid service data for mqtt.publish: Invalid MQTT topic name for dictionary value @ data['topic']. Got 'owntracks/#'
2018-01-18 20:09:16 ERROR (MainThread) [homeassistant.core] Invalid service data for mqtt.publish: Invalid MQTT topic name for dictionary value @ data['topic']. Got 'owntracks/#'
2018-01-18 20:09:17 ERROR (MainThread) [homeassistant.core] Invalid service data for mqtt.publish: Invalid MQTT topic name for dictionary value @ data['topic']. Got 'owntracks/#'
2018-01-18 20:09:18 ERROR (MainThread) [homeassistant.core] Invalid service data for mqtt.publish: Invalid MQTT topic name for dictionary value @ data['topic']. Got 'owntracks/#'
2018-01-18 20:09:19 ERROR (MainThread) [homeassistant.core] Invalid service data for mqtt.publish: Invalid MQTT topic name for dictionary value @ data['topic']. Got 'owntracks/#'
2018-01-18 20:09:20 ERROR (MainThread) [homeassistant.core] Invalid service data for mqtt.publish: Invalid MQTT topic name for dictionary value @ data['topic']. Got 'owntracks/#'
Eveything is, i suppose set up propely. Here is my config.yaml:
device_tracker:
- platform: owntracks
max_gps_accuracy: 100
waypoints: True
mqtt:
broker: 192.168.0.12
port: 1883
keepalive: 60
client_id: hassio
username: HIDDEN
password: HIDDEN
Here is my automations.yaml:
- alias: Refresh owntracks
- platform: time
minutes: '/1'
- service: mqtt.publish
topic: owntracks/#
payload_template: '{{ "_type": "cmd","action": "reportLocation" }}'
Well i’m completely stuck this time, any help could be really appriciated
I’m adding that i can upload my battery % with owntracks to home assistant UI via the dedicated sensor.
I can see the owntracks position push when connected to my broker with MQTT.fx and i can also publish from the developer tools.
It’s really frustrating, i am really close to it…
Change:
topic: owntracks/#
to:
topic: phone/phone
enable: homeassistant.components.mqtt: debug
and you will see what topic you must use.
I’m triyng right now, thanks a lot!
I’m now getting a long Traceback:
2018-01-18 21:07:10 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/src/app/homeassistant/helpers/template.py", line 90, in ensure_valid
self._compiled_code = ENV.compile(self.template)
File "/usr/local/lib/python3.6/site-packages/jinja2/environment.py", line 591, in compile
self.handle_exception(exc_info, source_hint=source_hint)
File "/usr/local/lib/python3.6/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python3.6/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "<unknown>", line 1, in template
File "/usr/local/lib/python3.6/site-packages/jinja2/environment.py", line 497, in _parse
return Parser(self, source, name, encode_filename(filename)).parse()
File "/usr/local/lib/python3.6/site-packages/jinja2/parser.py", line 901, in parse
result = nodes.Template(self.subparse(), lineno=1)
File "/usr/local/lib/python3.6/site-packages/jinja2/parser.py", line 876, in subparse
self.stream.expect('variable_end')
File "/usr/local/lib/python3.6/site-packages/jinja2/lexer.py", line 384, in expect
self.name, self.filename)
jinja2.exceptions.TemplateSyntaxError: expected token 'end of print statement', got ':'
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 180, in _step
result = coro.send(None)
File "/usr/src/app/homeassistant/core.py", line 1031, in _event_to_service_call
yield from service_handler.func(service_call)
File "/usr/src/app/homeassistant/components/mqtt/__init__.py", line 402, in async_publish_service
template.Template(payload_template, hass).async_render()
File "/usr/src/app/homeassistant/helpers/template.py", line 112, in async_render
self._ensure_compiled()
File "/usr/src/app/homeassistant/helpers/template.py", line 160, in _ensure_compiled
self.ensure_valid()
File "/usr/src/app/homeassistant/helpers/template.py", line 92, in ensure_valid
raise TemplateError(err)
homeassistant.exceptions.TemplateError: TemplateSyntaxError: expected token 'end of print statement', got ':'
2018-01-18 21:07:11 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
2018-01-18 21:07:12 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
2018-01-18 21:07:13 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
2018-01-18 21:07:14 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
2018-01-18 21:07:14 WARNING (MainThread) [homeassistant.core] Unable to find service input_number/select_value
2018-01-18 21:07:15 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
2018-01-18 21:07:15 WARNING (MainThread) [homeassistant.core] Unable to find service input_number/select_value
2018-01-18 21:07:16 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
2018-01-18 21:07:17 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
I cut the rest it was long.
I’m lost and i really need your help. I don’t understand this problem.
Thanks.
do i have to add this to config.yaml?
Whith this line in the config, home assistant don’t boot:
2018-01-18 21:17:04 ERROR (SyncWorker_0) [homeassistant.util.yaml] mapping values are not allowed here
in "/config/configuration.yaml", line 473, column 38
2018-01-18 21:17:04 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: mapping values are not allowed here
Add one space to all line in our automations.yaml for Refresh owntracks :
trigger:- platform: time
minutes: ‘/1’
action: - service: mqtt.publish
topic: owntracks/#
payload_template: ‘{{ “_type”: “cmd”,“action”: “reportLocation” }}’
- platform: time
yes in configuration.yaml add
logger:
default: warning
logs:
Thanks a lot, i’m using yamlit a lot.This is driving me crazy, my yaml seemse to be valid.
Also use cmd after valid topic: example
topic: "owntracks/phone/phone/cmd"
Nothing works for me it’s complete madness.
I even have the Show Google Maps as a card component working fine:
camera:
platform: generic
still_image_url: https://maps.googleapis.com/maps/api/staticmap?center={{ states.device_tracker.roman_romkilla.attributes.latitude }},{{ states.device_tracker.roman_romkilla.attributes.longitude }}&zoom=13&size=500x500&maptype=roadmap&markers=color:blue%7Clabel:P%7C{{ states.device_tracker.roman_romkilla.attributes.latitude }},{{ states.device_tracker.roman_romkilla.attributes.longitude }}
limit_refetch_to_url_change: true
No luck with owntracks mqtt topics
Again here is my log after a fresh restart:
2018-01-18 21:42:23 WARNING (MainThread) [homeassistant.setup] Setup of sensor is taking over 10 seconds.
2018-01-18 21:42:23 WARNING (MainThread) [homeassistant.setup] Setup of media_player is taking over 10 seconds.
2018-01-18 21:42:24 WARNING (MainThread) [homeassistant.setup] Setup of switch is taking over 10 seconds.
2018-01-18 21:42:24 WARNING (MainThread) [homeassistant.setup] Setup of device_tracker is taking over 10 seconds.
2018-01-18 21:42:24 WARNING (MainThread) [homeassistant.setup] Setup of remote is taking over 10 seconds.
2018-01-18 21:42:29 WARNING (MainThread) [homeassistant.setup] Setup of tts is taking over 10 seconds.
2018-01-18 21:42:44 WARNING (MainThread) [homeassistant.components.media_player] Setup of platform cast is taking over 10 seconds.
2018-01-18 21:42:53 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
2018-01-18 21:42:54 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
2018-01-18 21:42:55 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
2018-01-18 21:42:56 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
2018-01-18 21:42:57 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
2018-01-18 21:42:58 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
2018-01-18 21:42:59 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
2018-01-18 21:43:00 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
self.ensure_valid()
Hope someone could find a solution.
Thanks again Vlad.
You have problem with Refresh owntracks in automation.yaml:
jinja2.exceptions.TemplateSyntaxError: expected token ‘end of print statement’, got ‘:’
Comment it out and restart ha. Check log file
I finaly make your command works, here is the result:
2018-01-18 21:56:01 INFO (MainThread) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt
2018-01-18 21:56:02 INFO (MainThread) [homeassistant.loader] Loaded history from homeassistant.components.history
2018-01-18 21:56:02 INFO (MainThread) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2018-01-18 21:56:03 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=logger, service=set_level>
2018-01-18 21:56:03 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 1.3 seconds.
2018-01-18 21:56:03 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=logger>
2018-01-18 21:56:06 INFO (MainThread) [homeassistant.setup] Setting up mqtt
2018-01-18 21:56:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=mqtt, service=publish>
2018-01-18 21:56:06 INFO (MainThread) [homeassistant.setup] Setup of domain mqtt took 0.2 seconds.
2018-01-18 21:56:06 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=mqtt>
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.setup] Setting up http
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=http>
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.setup] Setting up api
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=websocket_api>
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.setup] Setting up system_log
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.2 seconds.
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=api>
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=system_log, service=clear>
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.1 seconds.
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=system_log>
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.setup] Setting up frontend
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=frontend, service=set_theme>
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=frontend, service=reload_themes>
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.2 seconds.
2018-01-18 21:56:08 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=frontend>
2018-01-18 21:56:09 INFO (MainThread) [homeassistant.setup] Setting up recorder
2018-01-18 21:56:09 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=recorder, service=purge>
2018-01-18 21:56:11 DEBUG (Recorder) [homeassistant.components.recorder] Connected to recorder database
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 1.7 seconds.
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=recorder>
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.setup] Setting up history
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=history>
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.loader] Loaded wake_on_lan from homeassistant.components.wake_on_lan
2018-01-18 21:56:11 ERROR (MainThread) [homeassistant.loader] Unable to find component logs
2018-01-18 21:56:11 ERROR (MainThread) [homeassistant.setup] Setup failed for logs: Component not found.
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.loader] Loaded tts.google from homeassistant.components.tts.google
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2018-01-18 21:56:11 ERROR (MainThread) [homeassistant.loader] Unable to find component homeassistant.components.mqtt
2018-01-18 21:56:11 ERROR (MainThread) [homeassistant.setup] Setup failed for homeassistant.components.mqtt: Component not found.
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.setup] Setting up input_select
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=input_select, service=select_option>
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=input_select, service=select_next>
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=input_select, service=select_previous>
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=input_select, service=set_options>
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.setup] Setting up input_number
2018-01-18 21:56:11 ERROR (MainThread) [homeassistant.loader] Unable to find component default
2018-01-18 21:56:11 ERROR (MainThread) [homeassistant.setup] Setup failed for default: Component not found.
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.loader] Loaded zone from homeassistant.components.zone
2018-01-18 21:56:11 INFO (MainThread) [homeassistant.setup] Setting up zone
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.loader] Loaded switch from homeassistant.components.switch
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.loader] Loaded group from homeassistant.components.group
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.loader] Loaded switch.wake_on_lan from homeassistant.components.switch.wake_on_lan
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.setup] Setting up sun
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.4 seconds.
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sun>
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.loader] Loaded ifttt from homeassistant.components.ifttt
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.loader] Loaded scene from homeassistant.components.scene
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.loader] Loaded scene.homeassistant from homeassistant.components.scene.homeassistant
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.setup] Setting up scene
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.loader] Loaded conversation from homeassistant.components.conversation
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.loader] Loaded camera from homeassistant.components.camera
2018-01-18 21:56:12 INFO (MainThread) [homeassistant.loader] Loaded camera.generic from homeassistant.components.camera.generic
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded remote from homeassistant.components.remote
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded remote.harmony from homeassistant.components.remote.harmony
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded media_player.yamaha_musiccast from homeassistant.components.media_player.yamaha_musiccast
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded media_player.cast from homeassistant.components.media_player.cast
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded device_tracker.owntracks from homeassistant.components.device_tracker.owntracks
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded config from homeassistant.components.config
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded dyson from homeassistant.components.dyson
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded hue from homeassistant.components.hue
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded sensor.yr from homeassistant.components.sensor.yr
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded sensor.mqtt from homeassistant.components.sensor.mqtt
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.setup] Setting up sensor
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.setup] Setting up group
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.default_view, old_state=None, new_state=<state group.default_view=unknown; entity_id=('group.plugs', 'group.pieces', 'group.harmony_hub', 'group.themes', 'group.air', 'group.google_audio', 'group.av_ampli', 'device_tracker.roman_romkilla', 'device_tracker.gabriela', 'sensor.weather_temperature', 'sensor.weather_humidity', 'sensor.battery_a5', 'camera.roman', 'group.volume'), order=0, view=True, friendly_name=default_view, icon=mdi:home, hidden=True, assumed_state=False @ 2018-01-18T21:56:13.303052+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.salon_view, old_state=None, new_state=<state group.salon_view=unknown; entity_id=('group.salon', 'group.google_chromecast'), order=1, view=True, friendly_name=Salon, hidden=True, assumed_state=False @ 2018-01-18T21:56:13.311702+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.harmony_switch_view, old_state=None, new_state=<state group.harmony_switch_view=unknown; entity_id=('group.harmony_switch', 'group.home_cinema'), order=2, friendly_name=Harmony Switch, assumed_state=False @ 2018-01-18T21:56:13.317343+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.cuisine_view, old_state=None, new_state=<state group.cuisine_view=unknown; entity_id=('group.cuisine',), order=3, view=True, friendly_name=Cuisine, hidden=True, assumed_state=False @ 2018-01-18T21:56:13.321624+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.chambre_view, old_state=None, new_state=<state group.chambre_view=unknown; entity_id=('group.chambre', 'group.google_home_mini'), order=4, view=True, friendly_name=Chambre, hidden=True, assumed_state=False @ 2018-01-18T21:56:13.327351+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.entree_view, old_state=None, new_state=<state group.entree_view=unknown; entity_id=('group.entree',), order=5, view=True, friendly_name=Entree, hidden=True, assumed_state=False @ 2018-01-18T21:56:13.331474+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.salon, old_state=None, new_state=<state group.salon=unknown; entity_id=('light.lamp_1', 'light.lamp_2', 'light.spot_1', 'light.spot_2', 'light.strip_1', 'light.bloom_1', 'light.living'), order=6, friendly_name=Salon, icon=mdi:lightbulb, assumed_state=False @ 2018-01-18T21:56:13.340142+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.themes, old_state=None, new_state=<state group.themes=unknown; entity_id=('input_select.hass_theme',), order=7, friendly_name=Themes, assumed_state=False @ 2018-01-18T21:56:13.348156+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.av_ampli, old_state=None, new_state=<state group.av_ampli=unknown; entity_id=('media_player.home_cinema_main',), order=8, friendly_name=Yamaha, assumed_state=False @ 2018-01-18T21:56:13.352946+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.google_home_mini, old_state=None, new_state=<state group.google_home_mini=unknown; entity_id=('media_player.google_home_mini',), order=9, friendly_name=Google Home Mini, assumed_state=False @ 2018-01-18T21:56:13.358071+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.google_audio, old_state=None, new_state=<state group.google_audio=unknown; entity_id=('media_player.google_home',), order=10, friendly_name=Google Audio, assumed_state=False @ 2018-01-18T21:56:13.363026+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.google_chromecast, old_state=None, new_state=<state group.google_chromecast=unknown; entity_id=('media_player.chromecast_audio',), order=11, friendly_name=Google Chromecast, assumed_state=False @ 2018-01-18T21:56:13.367274+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.plugs, old_state=None, new_state=<state group.plugs=unknown; entity_id=('light.free', 'switch.wake_on_lan', 'light.astro', 'light.multi'), order=12, friendly_name=Plugs, assumed_state=False @ 2018-01-18T21:56:13.372362+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.air, old_state=None, new_state=<state group.air=unknown; entity_id=('sensor.salon_temperature', 'sensor.salon_humidity', 'fan.salon'), order=13, friendly_name=Air, assumed_state=False @ 2018-01-18T21:56:13.378351+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.harmony_hub, old_state=None, new_state=<state group.harmony_hub=unknown; entity_id=('input_select.harmony_hub', 'script.input_select_harmony'), order=14, friendly_name=Harmony Hub, assumed_state=False @ 2018-01-18T21:56:13.383140+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.volume, old_state=None, new_state=<state group.volume=unknown; entity_id=('input_number.slider1', 'input_number.slider2'), order=15, friendly_name=Volume, assumed_state=False @ 2018-01-18T21:56:13.387128+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.harmony_switch, old_state=None, new_state=<state group.harmony_switch=unknown; entity_id=('script.1515326774093', 'script.1515327048655', 'script.1515327237237', 'script.1515327331527', 'script.1515327471008', 'script.1515327517610', 'script.1515327540596', 'script.1515327559406', 'script.1515327583972', 'script.1515327610370', 'script.1515327627914', 'script.1515327641814', 'script.1515327655098', 'script.1515327674292', 'script.1515326774093', 'script.1515327688932', 'script.1515327707943', 'script.1515327731548', 'script.1515327816025', 'script.1515327847785', 'script.1515327905431', 'script.1515337890501', 'script.1515352957625', 'script.1515352997947', 'script.1515353133084', 'script.1515353224614', 'script.1515353304047', 'script.1515353427055', 'script.1515356098614'), order=16, friendly_name=Harmony Switch, assumed_state=False @ 2018-01-18T21:56:13.392227+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.home_cinema, old_state=None, new_state=<state group.home_cinema=unknown; entity_id=('automation.movies_tv_started_from_harmony_hub', 'automation.movies_started_from_harmony_hub', 'automation.pc_play_started_from_harmony_hub', 'automation.pc_stop_started_from_harmony_hub', 'automation.poweroff_started_from_harmony_hub', 'automation.back_harmony', 'automation.play_harmony', 'scene.livingroom_dim', 'scene.livingroom_normal', 'scene.livingroom_off'), order=17, friendly_name=Home Cinema, assumed_state=False @ 2018-01-18T21:56:13.398861+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.remotes, old_state=None, new_state=<state group.remotes=unknown; entity_id=('remote.harmony_hub',), order=18, friendly_name=Remotes, assumed_state=False @ 2018-01-18T21:56:13.404122+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.pieces, old_state=None, new_state=<state group.pieces=unknown; entity_id=('light.salon', 'light.entree', 'light.cuisine', 'light.chambre'), order=19, friendly_name=Pieces, icon=mdi:door, assumed_state=False @ 2018-01-18T21:56:13.409731+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.chambre, old_state=None, new_state=<state group.chambre=unknown; entity_id=('light.lamp_6',), order=20, friendly_name=Chambre, assumed_state=False @ 2018-01-18T21:56:13.415155+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.cuisine, old_state=None, new_state=<state group.cuisine=unknown; entity_id=('light.lamp_4', 'light.lamp_5'), order=21, friendly_name=Cuisine, assumed_state=False @ 2018-01-18T21:56:13.421342+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.entree, old_state=None, new_state=<state group.entree=unknown; entity_id=('light.lamp_3',), order=22, friendly_name=Entree, assumed_state=False @ 2018-01-18T21:56:13.426486+01:00>>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded map from homeassistant.components.map
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.setup] Setting up map
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=map>
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded script from homeassistant.components.script
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded automation.state from homeassistant.components.automation.state
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded automation.event from homeassistant.components.automation.event
2018-01-18 21:56:13 INFO (MainThread) [homeassistant.loader] Loaded automation.time from homeassistant.components.automation.time
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.loader] Loaded emulated_roku from custom_components.emulated_roku
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_data=title=Invalid config, message=The following components and platforms could not be set up:
- logs
Please check your config., notification_id=invalid_config, service_call_id=139649613309712-1>
- logs
- homeassistant.components.mqtt
Please check your config., notification_id=invalid_config, service_call_id=139649613309712-2>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=input_select.harmony_hub, old_state=None, new_state=<state input_select.harmony_hub=Power Off; options=['Power Off', 'MOVIES', 'PC', 'PS4', '360 TV', 'SMART TV', 'WiiU TV', 'TV', 'Chromecast audio', 'PS3 TV', 'WiiU', 'ONE', 'SWITCH TV', 'MOVIES TV', 'PS3', '360', 'PS4 TV', 'SWITCH', 'PC TV', 'ONE TV'], friendly_name=Activity, icon=mdi:monitor, entity_picture=/local/harmony.jpg @ 2018-01-18T21:56:14.073677+01:00>>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=input_select.hass_theme, old_state=None, new_state=<state input_select.hass_theme=default; options=['default', 'solarized', 'PmxMononight', 'Night'], friendly_name=HASS Themes, icon=mdi:theme-light-dark @ 2018-01-18T21:56:14.079431+01:00>>
- logs
- default
Please check your config., notification_id=invalid_config, service_call_id=139649613309712-3>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zone.home, old_state=None, new_state=<state zone.home=zoning; hidden=True, latitude=43.270909, longitude=6.63785, radius=60.0, friendly_name=Home, icon=mdi:home @ 2018-01-18T21:56:14.090278+01:00>>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=zone.work, old_state=None, new_state=<state zone.work=zoning; hidden=True, latitude=43.268606, longitude=6.640683, radius=30.0, friendly_name=Work, icon=mdi:briefcase @ 2018-01-18T21:56:14.095623+01:00>>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=None, new_state=<state sun.sun=below_horizon; next_dawn=2018-01-19T06:29:23+00:00, next_dusk=2018-01-19T16:58:38+00:00, next_midnight=2018-01-18T23:44:10+00:00, next_noon=2018-01-19T11:44:00+00:00, next_rising=2018-01-19T07:00:44+00:00, next_setting=2018-01-19T16:27:17+00:00, elevation=-48.12, azimuth=289.8, friendly_name=Sun @ 2018-01-18T21:56:14.101103+01:00>>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.invalid_config, old_state=None, new_state=<state persistent_notification.invalid_config=notifying; title=Invalid config, message=The following components and platforms could not be set up:
- logs
Please check your config. @ 2018-01-18T21:56:14.154976+01:00>>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=139649613309712-1>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.invalid_config, old_state=<state persistent_notification.invalid_config=notifying; title=Invalid config, message=The following components and platforms could not be set up:
- logs
Please check your config. @ 2018-01-18T21:56:14.154976+01:00>, new_state=<state persistent_notification.invalid_config=notifying; title=Invalid config, message=The following components and platforms could not be set up:
- logs
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=139649613309712-2>
- logs
- logs
- default
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=139649613309712-3>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=input_number, service=set_value>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=input_number, service=increment>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=input_number, service=decrement>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.setup] Setting up logbook
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 2.4 seconds.
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=input_select>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 2.2 seconds.
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=zone>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=input_number.slider2, old_state=None, new_state=<state input_number.slider2=40.0; min=0.0, max=100.0, step=10.0, mode=slider, friendly_name=Yamaha @ 2018-01-18T21:56:14.239835+01:00>>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=input_number.slider1, old_state=None, new_state=<state input_number.slider1=40.0; min=0.0, max=100.0, step=10.0, mode=slider, friendly_name=Google Home @ 2018-01-18T21:56:14.246051+01:00>>
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.setup] Setting up camera
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.setup] Setting up media_player
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.setup] Setting up config
2018-01-18 21:56:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=logbook, service=log>
And here is my automation:
- platform: time
minutes: '/1'
With MQTT.fx when publishing from the phone it goes on my broker: owntracks/roman/romkilla
{"_type":"location","tid":"05","acc":1100,"batt":88,"conn":"m","lat":43.2722742,"lon":6.6375902,"tst":1516310651}
I followed this example on this post
eventually ended up with
- alias: Refresh Owntracks
- platform: time
minutes: '/30'
data_template:
payload: "{ \"_type\": \"cmd\", \"action\":\"reportLocation\" }"
it generates no errors and i can see the published message on my MQTT.fx
Thanks mate, i don’t have error in the log now !
How can i see the updated location on the UI map ?
I don’t see anything on the map.
Thanks again.
