OWON PC321-Z-TY power clamp not recognized in Home Assistant
I’m totally new to Home Assistant.
I would like to monitor the electricity usage.
My Home Assistant works normally with different peripherals.
When I add a new device the OWON PC321 is recognized like : TZE200_nslr42tt TS0601 which seems to be a thermostat.
How can I do to make it work properly ?
Thanks for your help.
You must connect the meter to a Tuya Zigbee gateway. With your Tuya addon yo can integrate the meter to your HA. I use the same meter for a day. I will checkout the accurcy of the meter.
Also one clamp seems with incorrect data.
