Not sure if it’s directly related to this forum. But as part of installation. I’ve seen several intructions but they all relate to installing outside the virtual enviroment.
I followed up the instruction installing into VE. Got home assistant and open zwave installed. Now all is needed is the z-wave control panel.
It is also supposed to be installed into VE?
I’m having problem installing the libmicrohttpd. Try to make it inside the VE and get the following error
/bin/install -c -m 644 microhttpd.h '/usr/local/include'
/bin/install: cannot create regular file ‘/usr/local/include/microhttpd.h’: Permission denied
Looking at this… Should i install the library outside the VE? Or somehow correct the installation process and install it in VE?
And the instructions i found install the libmicrohttpd-0.9.19.tar.gz which is dated 2012. Is it on purpose or it’s better of getting the latest one?
And there is a CENTOS package
libmicrohttpd.x86_64 : Lightweight library for embedding a webserver in applications
So maybe skip the compuling step?
