OZW quit, and I think I made things works by attempting a migration to JS
Hi all-
Pi4
Aeotec Z-Stick Gen5 Z-Wave using a USB Hub to get around the USB problems this stick was having.
Not sure Core and Supervisor versions, I stopped updating them in Feb or March when the release notes mentioned that OZW support was being removed
Everything was working fine until I woke up to my z-wave integration not functioning properly, all devices in an ‘unavailable’ state. I performed a reboot to no luck. After initial troubleshooting to make sure the USB stick was plugged in, ensuring device path was correct, etc; I figured that now would be a great time to migrate to Z Wave JS. In hindsight, attempting a migration when the base config was not functioning was a blunder.
Ultimately, I decided to rollback to a fully operating backup. Again, another blunder was not putting core and supervisor info in the backup file name. I used the latest image, restored the backup and I’m in the same spot. OZW does not seem to be functioning. And in this broken state, I cannot seem to migrate to Z Wave JS. The other option is that the stick has failed, but I am not sure how to test that.
Presently, running core 2021.12.3 and supervisor 2022.04.0.
I have removed OZW. Rebooted, and installed the Z Wave JS supervisor and integration (again). None of the z wave devices are being pulled in. The supervisor error I get it:
Unable to start driver ZWaveError: The security key for class S0_Legacy must be a buffer with length 16! (ZW0108)
    at checkOptions (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:285:11)
    at new Driver (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:449:3)
    at /usr/src/node_modules/@zwave-js/server/dist/bin/server.js:96:11
    at Object.<anonymous> (/usr/src/node_modules/@zwave-js/server/dist/bin/server.js:134:3)
    at Module._compile (internal/modules/cjs/loader.js:1085:14)
    at Object.Module._extensions..js (internal/modules/cjs/loader.js:1114:10)
    at Module.load (internal/modules/cjs/loader.js:950:32)
    at Function.Module._load (internal/modules/cjs/loader.js:790:12)
    at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:75:12)
    at internal/main/run_main_module.js:17:47 {
  code: 108,
  context: undefined,
  transactionSource: undefined
Puting the supervisor server in Debug mode allows the integration to connect to the server, but does not pull over any devices and I receive errors on the server:
New client
Unexpected error TypeError: driver.controller.getProvisioningEntries is not a function
    at Function.handle (/usr/src/node_modules/@zwave-js/server/dist/lib/controller/message_handler.js:50:51)
    at Object.controller (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:37:103)
    at Client.receiveMessage (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:95:99)
    at WebSocket.<anonymous> (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:48:45)
    at WebSocket.emit (events.js:400:28)
    at WebSocket.emit (domain.js:475:12)
    at Receiver.receiverOnMessage (/usr/src/node_modules/ws/lib/websocket.js:1137:20)
    at Receiver.emit (events.js:400:28)
    at Receiver.emit (domain.js:475:12)
    at Receiver.dataMessage (/usr/src/node_modules/ws/lib/receiver.js:528:14)
Deleting the legacy code, and letting it be auto configured allows the supervisor server to work without error, but breaks the Z Wave JS integration piece. Deleting, rebooting and attempting new install of the integration provides a ‘abort’ and failed to connect.
What should my next troubleshooting steps be?
OZW wasn’t working to start so maybe there is other issue.
In the end I expect you will need to reset everything and start over. Unfortunately it is the quickest, but maybe not easiest, route.
It sounds like Zwave js can see the aeotec stick correct? If so, I’d reset and readd all devices. Due to how items get migrated you’d effectively be in same boat getting entity names matched if you moved from working install. Starting Over may save time.
If Zwave js cannot see aeotec then that would need to be sorted before determining next step
If it shows up on system and can be seen in zwavejs….you can assume it works
Thanks. That is a bummer, but not necessarily unexpected news. Its been a few years, 29 physical devices… probably is time for a refresh. Next step is to figure out how to reset the devices and re-adopt, I’ll probably get a new stick for the sake of being completely fresh with the new load.
