I have some GE Switches and Dimmers that require a frequent poll to get their status to sync correctly with home assistant.
Is there a compatible setting for zwave2mqtt or ozwdaemon?
I haven’t been able to find one and my lights are out of sync which is very confusing when using either zwave2mqtt or ozedaemon
Here’s how I do it with the native zwave integration.
light.jasco_products_28167_zw3104_plug_in_smart_dimmer_single_plug_level_2:
ignored: false
polling_intensity: 1
refresh_value: true
delay: 1
fgonza2
(Fgonza2)
October 12, 2020, 6:55pm
2
send an MQTT message to: OpenZWave/1/command/enablepoll/
All message payloads are JSON, example:
"ValueIDKey": 105480209,
"Intensity": 1
Go to your MQTT messages using MQTT explorer or other, go in the node,
more info here
I’ll give that a try. Is the valueIDKey 105480209
an actual key or is that specific to your setup?
fgonza2
(Fgonza2)
October 12, 2020, 7:48pm
4
each key is unique, you need to find it in yours, the screenshot is on my setup. You need to find the valueID for your device in your setup, they are all different
istvanSA
(Istvan Sa)
October 25, 2020, 9:41am
5
if i would have polling enabled for this device : how would i do that
homeassistant/6/50/6/2
"value_id": "6-50-6-2",
"node_id": 6,
"class_id": 50,
"type": "decimal",
"genre": "user",
"instance": 6,
"index": 2,
"label": "Instance 6: Electric - W",
"units": "W",
"help": "",
"read_only": true,
"write_only": false,
"min": 0,
"max": 0,
"is_polled": false,
"value": 24.5,
"lastUpdate": 1603617721849
this is a greenpower 6 port switch, in domoticz which i used before i enable polling for this device since somehow it doens tupdate its power usage reliably and ust stops reporting it a lot of times. In zwave2mqtt if i do an “refreshnodeinfo” it reports for a while again
