P1 meter works: energy dashboard: No matching statistics found for consumption
Just got my p1 cable today for my ISKRA AM550 (DSMR 5.0)
Managed to install to home assistant (on Intel Nuc), HA up to date
DSMR integration installed fine, I see 2 devices and 28 entities and made a simple card showing gas en electric consumption. That is simple but works.
I now want to set up the energy dashboard but for consumption I get “No matching statistics found” - any clue what to do here? Googled a bit and found some manual setup - is that required and if so what and how?
Rebooted a few times, waited a bit to get some data history but unsure what to do next.
Hi Jasper,
do your sensors have a value right now? Like in this screenshot?
Thanks Jan,
Yes I get data, see attached. I have no production (no panels) however could select the sensors. In the integration more entities are shown as disabled (things like phase 1/2).
Energy seems to be working (day / night) and one for gas.
dash2
All energy types (read kWh values) should be available to configure your Energy Dashboard.
When you finish your configuration it can take up to two hours to have the first figures in your Dashboard display.
You can configure it like the picture below. (We have the same meter :wink: )
Thanks Jan. However I am stuck in the wizard for the energy dashboard.
If I open it a wizard opens
If I then enter energy consumption I get this:
No matching statistics found. So can’t complete the wizard
That’s strange. All kWh sensors should appear in the drop-down list!
Please can you check the Developer Tools → Statistics, search for Energy and check the value in the third column. It should also have the value kWh.
The fifth column should have the value “No issue” If it lists repair, click on it to auto repair.
otherwise, I have no clue, perhaps some other forum user can help further?
Thanks that was it! I once excluded some domains/entities from recorder to keep logsize down.
Wasn’t aware of this screen but it pointed me in the right direction. Everything working now, thx!!!
