P1 Monitor communication error
Dear friends, unfortunately I suddenly have a problem with P1 monitor communication. I’ve tried reinstalling, but that doesn’t help. The P1 monitor does work because I can read 1:1 on the local web page of P1 monitor. Please you help what to do? Everything worked fine for a year.
Error Message: Retrying setup: Error occurred while communicating with P1 Monitor device
this happened to me as well when updating to the new Home Assistant OS 9.0.
What fixed it for me is to remove the integration from HA and upgrade your P1 monitor device to the latest firmware version (download is available from their website). Could be that the integration version and your P1 monitor device don’t cooperate nicely anymore.
I suggest you do a database backup via the P1 monitor web interface first so you dont lose all your collected data.
Yes, it works, your tip was the solution! Thank you very much for your help, much appreciated.
