P1 Wrong gas value
Config:
Kaifa MA304C DSMR 4.2.2
DSMR (Zuidwijk - P1 reader ethernet v3.4)
HomeAssistant
Used guid integration to add the “DSMR Slimme Meter” integration.
options: Network, , DSMR v4
After that the electricity usage works fine.
Problem:
Gas Consumption" sensor shows a steady 00001,287m3
The display on the gas meter shows 06804,354m3
The telnet output of the P1 shows:
/KFM5KAIFA-METER
1-3:0.2.8…
…1-0:62.7.0(00.000*kW)
0-1:24.1.0(003)
0-1:96.1.0(4730303332353631323638313931343136)
0-1:24.2.1(170113170000W)(00001.287*m3)
0-2:24.1.0(003)
0-2:96.1.0(4730303332353631323638313932353136)
0-2:24.2.1(210922090000S)(06804.354*m3)
!FE16
I Have the same type of problem. Did you find an solution?
Same issue here. I think it’s because there are two different gas values.
Does anyone have a solution?
