trying to move my xbox one hassio addon and related components into a package but i get an error. It works if i leave the template switch in the seperate switches.yaml
Invalid config for [switch]: required key not provided @ data['platform']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/switch/
Any help would be appreciated!
switch:
switches:
xboxone:
value_template: "{{ is_state('sensor.eeeeeediot', 'Online') }}"
turn_on:
service: rest_command.xbox
power: "poweron"
turn_off:
power: "poweroff"
friendly_name: "Xbox One"
rest_command:
xbox:
url: 'http://192.168.0.xx:5557/device/xxxxxxxxxxxxxxxxxx/{{power}}'
# Xbox Live sensor. tells current state of xbox
- platform: xbox_live
scan_interval: 90
api_key: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
xuid:
- xxxxxxxxxxxxxxxxxxx
# Xbox template sensor . Tells current state of xbox
sensors:
xboxone_status:
friendly_name: "Eeeeeediot"
value_template: >
{% if is_state('sensor.eeeeeediot', 'Offline') %}
Offline
{% elif is_state('sensor.eeeeeediot', 'Online') %}
{{ states.sensor.eeeeeediot.attributes["XboxOne Full"] }}
{% else %}
Home
{% endif %}
#xbox switch in switch.yaml - wouldnt copy over and validate correctly
