Have removed the entire customize: under homeassistant:, but even then I keep on receiving the error
“Package homeassistant contains invalid customize” after a HA restart.
The issue being that homeassistant: was twice in my configuration. I moved everything under homeassistant in the package to the configuration.yaml, and removed the package. Now works like a sharm again.
@frenck and @JuanM, I’m quite sure you’re currently facing the same issue since I looked at your configs when changing my config to use packages.
Hmmm, still don’t understand it, may be I’m overlooking something here. If I move the customize to the homeassistant package like Frenck’s config, the error occurs again and customizations don’t work.
I just keep the customize in the configuration.yaml for now, and not use a homeassistant package, that resolves it.
Same issue here. also things like whitelist_external_dir work only in the main yaml (within the root). Not a problem for me though to have the homeassistant config in the root file.
