Packages and !include in ESPHome fail
Hi, all!
I am playing with packages and !include the the yaml file in ESPHome, but it seems I am missing something.
First I define common/sensor/wifi_signal.config.yaml
- platform: wifi_signal
  name: ${friendly_name} WiFi signal
  update_interval: 600s
Then I would reference this in the main configuration file, eg. /config/esphome/led_sofie_tak.yaml
  - !include common/sensor/wifi_signal.config.yaml
  - platform: dallas
    unit_of_measurement: "°C"
    index: 0
    filters:
      - offset: -3.7
I get this error when validating
Failed config
sensor.unknown: [source /config/esphome/led_sofie_tak.yaml:42]
  Platform schemas must be key-value pairs.
  - platform: uptime
    name: LED Sofie tak Uptime
The packages reference:
packages:
  wifi: !include common/wifi.yaml
validates OK, though :slight_smile:
What am I missing here?
Solved this!
Solution is to not use the !include statement within sensor:, but rather put the !include: within packages: which will be defined in the top level config.yaml (/config/esphome/led_sofie_tak.yaml)
I then realized the sensor: can be defined both from a local reference within the config.yaml and in a referenced yaml via !include:
