I have start using packages and got it working.
But the automations from packages are shwoing greyed out in automations (see picture).
They do not run.
no it normally doesn’t grey them out you just get a message if you try to edit it.
Have you tried reloading the automations?
If you click on the automation you should get a cog in top right click on cog… does it say entity can be deleted?
Normally the pen only shows if the automation has an id, otherwise it is greyed out. Even if it has an id, you still can’t edit it from the UI unless it is in automations.yaml in the root directory.
OK greyed out is the normal beheviour then. I knew they are no longer editable in the GUI. Would be nice if it could. After multiple restarts and tinkering they work now.
