After using home assistant for a year now I finally got to the point where my config file is now almost unmanageable and therefore I want to split it with the packages machanism.
However I have some problems with it, even an easy extraction doesn’t work. My configuration.yaml
starts with
# Configure a default set of integrations for Home Assistant to load
# see https://www.home-assistant.io/integrations/default_config/
default_config:
# Enable configuration through packages
homeassistant:
packages: !include_dir_merge_named packages/
and I have one package (elias_alarm.yaml
) with the following content:
input_boolean:
elias_alarm_switch:
name: Elias Wecker einschalten
icon: mdi:alarm-check
input_datetime:
elias_alarm_time:
name: Elias Wecker Uhrzeit
has_date: false
has_time: true
icon: mdi:alarm
This works when it is in configuration.yaml
, but with packages I found the following in the log:
2020-07-02 10:01:15 ERROR (MainThread) [homeassistant.config] Package input_boolean setup failed. Integration elias_alarm_switch Integration 'elias_alarm_switch' not found. (See /config/packages/elias_alarm.yaml:1).
2020-07-02 10:01:15 ERROR (MainThread) [homeassistant.config] Package input_datetime setup failed. Integration elias_alarm_time Integration 'elias_alarm_time' not found. (See /config/packages/elias_alarm.yaml:6).
Can someone explain what I am doing wrong here?
Kind regards, Christian
