I’ve been using Hass.IO for my garage lights for a few weeks. I’m very pleased. Once I got some of the terminology sorted in my head (I’m still not here yet), it became smoother. I want to do a few more experiments before I release it on my house!
Namely, I want to receive some analog values from both Arduino and Rasberry Pi. I will also want to send some analog values (probably only to the Pi).
So, for the RPi, I’ve got a tweaked demo using Paho MQTT. It certainly receives the packet from Home Assistant: I go to developer tools / MQTT and issue plant/in with a payload of 123, and my Raspberry Pi prints the topic and payload. My Pi should also be publishing a value. I’ve used client.publish(“plant/out”,“50”).
So, first question: How do I get the published value in to HA? I believe I have to somehow make it recognise the published topic as an “entity”. I thought it might be as simple as adding to the configuration.yaml:
- platform: mqtt
state_topic: "plant/out"
But that has not made the entity appear in the dropdown list when I add a card. What stage have I missed?
Second question: When it comes to analog output (from HA to the RPi), is there a card I can use which has a dial or a slider to set the value?
Thanks.
