Hi, what are the required settings when IP150 is having “no site configuration”?
The IP150 is running Firmware 4.0.4. This firmware does not allow to access the command port (typically 10000) in a local network, it only allow access from SWAN using serial number.
To be clear, in babyware I am using this configuration
In PAI I only see 2 options:
Local IP Address: firmware version < 4.0 or >= 4.40.004
SITE ID firmware versions >4.0
but no specify what happens with version = 4.0
Thank you.
