I just removed all the “Unknown Node” from Home assistant. Reboot the PI. Did a factory reset on the lock.
Tried to pair the lock again and the same thing happened.
Here’s half of the the OZW log (the other half will be just below, because of characteres limitation)
2019-05-08 00:24:57.251 Always, OpenZwave Version 1.4.3433 Starting Up
2019-05-08 00:25:06.437 Info, Setting Up Provided Network Key for Secure Communications
2019-05-08 00:25:06.437 Warning, Failed - Network Key Not Set
2019-05-08 00:25:06.437 Info, mgr, Added driver for controller /dev/ttyACM0
2019-05-08 00:25:06.444 Info, Opening controller /dev/ttyACM0
2019-05-08 00:25:06.444 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2019-05-08 00:25:06.445 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2019-05-08 00:25:06.446 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-05-08 00:25:06.446 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-05-08 00:25:06.446 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-05-08 00:25:06.446 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-05-08 00:25:06.446 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-05-08 00:25:06.446 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2019-05-08 00:25:06.448 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x34, 0x2e, 0x35, 0x34, 0x00, 0x01, 0x93
2019-05-08 00:25:06.449 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2019-05-08 00:25:06.449 Info, contrlr, Static Controller library, version Z-Wave 4.54
2019-05-08 00:25:06.449 Detail, Node045, Expected reply was received
2019-05-08 00:25:06.449 Detail, Node045, Message transaction complete
2019-05-08 00:25:06.449 Detail, contrlr, Removing current message
2019-05-08 00:25:06.449 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2019-05-08 00:25:06.451 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xc7, 0x5c, 0x02, 0x80, 0x01, 0xce
2019-05-08 00:25:06.451 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xc75c0280. Our node ID = 1
2019-05-08 00:25:06.452 Detail, Node092, Expected reply was received
2019-05-08 00:25:06.452 Detail, Node092, Message transaction complete
2019-05-08 00:25:06.452 Detail, contrlr, Removing current message
2019-05-08 00:25:06.452 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2019-05-08 00:25:06.454 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x28, 0xd7
2019-05-08 00:25:06.454 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2019-05-08 00:25:06.454 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2019-05-08 00:25:06.454 Info, contrlr, The PC controller is a primary controller.
2019-05-08 00:25:06.454 Detail, Node215, Expected reply was received
2019-05-08 00:25:06.454 Detail, Node215, Message transaction complete
2019-05-08 00:25:06.454 Detail, contrlr, Removing current message
2019-05-08 00:25:06.454 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2019-05-08 00:25:06.458 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x01, 0x00, 0x86, 0x01, 0x01, 0x00, 0x5a, 0xfe, 0x81, 0xff, 0x88, 0x4f, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x00, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0xfb
2019-05-08 00:25:06.458 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2019-05-08 00:25:06.458 Info, contrlr, Serial API Version: 1.1
2019-05-08 00:25:06.458 Info, contrlr, Manufacturer ID: 0x0086
2019-05-08 00:25:06.458 Info, contrlr, Product Type: 0x0101
2019-05-08 00:25:06.458 Info, contrlr, Product ID: 0x005a
2019-05-08 00:25:06.459 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2019-05-08 00:25:06.459 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2019-05-08 00:25:06.459 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2019-05-08 00:25:06.459 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2019-05-08 00:25:06.459 Detail, Node001, Expected reply was received
2019-05-08 00:25:06.459 Detail, Node001, Message transaction complete
2019-05-08 00:25:06.459 Detail, contrlr, Removing current message
2019-05-08 00:25:06.459 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2019-05-08 00:25:06.461 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2019-05-08 00:25:06.461 Info, contrlr, Received reply to GET_SUC_NODE_ID. Node ID = 0
2019-05-08 00:25:06.461 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2019-05-08 00:25:06.461 Detail, Node172, Expected reply was received
2019-05-08 00:25:06.461 Detail, Node172, Message transaction complete
2019-05-08 00:25:06.461 Detail, contrlr, Removing current message
2019-05-08 00:25:06.461 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2019-05-08 00:25:06.517 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0x8e, 0xa2, 0xba, 0x8a, 0xae, 0x72, 0xa7, 0x57, 0x7a, 0x39, 0x6e, 0xf0, 0x05, 0x4a, 0x45, 0xb8, 0x51, 0xcc, 0x8b, 0xb1, 0x47, 0xff, 0x47, 0x22, 0x5d, 0x0a, 0xd0, 0xb0, 0x81, 0xd9, 0xe8, 0xe1, 0xa5
2019-05-08 00:25:06.518 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2019-05-08 00:25:06.518 Detail, Node032, Expected reply was received
2019-05-08 00:25:06.518 Detail, Node032, Message transaction complete
2019-05-08 00:25:06.518 Detail, contrlr, Removing current message
2019-05-08 00:25:06.518 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2019-05-08 00:25:06.622 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc5
2019-05-08 00:25:06.622 Info, mgr, Driver with Home ID of 0xc75c0280 is now ready.
2019-05-08 00:25:06.626 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2019-05-08 00:25:06.626 Info, contrlr, Node 001 - Known
2019-05-08 00:25:06.626 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2019-05-08 00:25:06.626 Detail, Node001, QueryStage_CacheLoad
2019-05-08 00:25:06.626 Info, Node001, Node Identity Codes: 0086:0101:005a
2019-05-08 00:25:06.626 Detail, Node001, QueryStage_Associations
2019-05-08 00:25:06.626 Detail, Node001, QueryStage_Neighbors
2019-05-08 00:25:06.626 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2019-05-08 00:25:06.626 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2019-05-08 00:25:06.626 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2019-05-08 00:25:06.627 Detail, Expected reply was received
2019-05-08 00:25:06.627 Detail, Message transaction complete
2019-05-08 00:25:06.627 Detail, contrlr, Removing current message
2019-05-08 00:25:06.627 Detail, Node001, Notification: DriverReady
2019-05-08 00:25:06.636 Detail, Node001, Notification: NodeAdded
2019-05-08 00:25:07.283 Detail, Node001, Notification: NodeProtocolInfo
2019-05-08 00:25:07.287 Detail, Node001, Notification: EssentialNodeQueriesComplete
2019-05-08 00:25:07.289 Detail, Node001, Notification: ValueAdded
2019-05-08 00:25:07.290 Detail, Node001, Notification: NodeNaming
2019-05-08 00:25:07.293 Detail,
2019-05-08 00:25:07.296 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2019-05-08 00:25:07.299 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x96, 0x0f, 0x64
2019-05-08 00:25:07.299 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2019-05-08 00:25:07.299 Detail, Node015, Expected reply was received
2019-05-08 00:25:07.299 Detail, Node015, Message transaction complete
2019-05-08 00:25:07.299 Detail, contrlr, Removing current message
2019-05-08 00:25:07.299 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2019-05-08 00:25:07.301 Detail, contrlr, Removing current message
2019-05-08 00:25:07.301 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2019-05-08 00:25:07.306 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5e
2019-05-08 00:25:07.306 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2019-05-08 00:25:07.306 Info, Node001, Neighbors of this node are:
2019-05-08 00:25:07.306 Info, Node001, (none reported)
2019-05-08 00:25:07.306 Detail, Expected reply was received
2019-05-08 00:25:07.306 Detail, Message transaction complete
2019-05-08 00:25:07.306 Detail, Node001, Removing current message
2019-05-08 00:25:07.306 Detail, Node001, Query Stage Complete (Neighbors)
2019-05-08 00:25:07.306 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2019-05-08 00:25:07.306 Detail, Node001, QueryStage_Session
2019-05-08 00:25:07.306 Detail, Node001, QueryStage_Dynamic
2019-05-08 00:25:07.306 Detail, Node001, QueryStage_Configuration
2019-05-08 00:25:07.306 Detail, Node001, QueryStage_Complete
2019-05-08 00:25:07.306 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2019-05-08 00:25:07.306 Warning, CheckCompletedNodeQueries all=1, deadFound=0 sleepingOnly=1
2019-05-08 00:25:07.307 Info, Node query processing complete.
2019-05-08 00:25:07.307 Detail, Node001, Notification: NodeQueriesComplete
2019-05-08 00:25:07.314 Detail, contrlr, Notification: AllNodesQueried
2019-05-08 00:27:19.796 Detail, Queuing (Controller) Add Device
2019-05-08 00:27:19.797 Info, Add Device
2019-05-08 00:27:19.797 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0a, 0x7b
2019-05-08 00:27:19.797 Detail, Notification: ControllerCommand - Starting
2019-05-08 00:27:19.801 Detail,
2019-05-08 00:27:19.801 Info, contrlr, Sending (Command) message (Callback ID=0x0a, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0a, 0x7b
2019-05-08 00:27:19.805 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x01, 0x00, 0x00, 0xb9
2019-05-08 00:27:19.805 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2019-05-08 00:27:19.805 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2019-05-08 00:27:19.805 Detail, Node001, Expected callbackId was received
2019-05-08 00:27:19.805 Detail, Node001, Expected reply was received
2019-05-08 00:27:19.805 Detail, Node001, Message transaction complete
2019-05-08 00:27:19.806 Detail,
2019-05-08 00:27:19.806 Detail, contrlr, Removing current message
2019-05-08 00:27:19.806 Detail, Notification: ControllerCommand - Waiting
2019-05-08 00:27:19.807 Info, WriteNextMsg Controller nothing to do
2019-05-08 00:27:25.163 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x02, 0x00, 0x00, 0xba
2019-05-08 00:27:25.163 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2019-05-08 00:27:25.163 Info, ADD_NODE_STATUS_NODE_FOUND
2019-05-08 00:27:25.163 Detail, Notification: ControllerCommand - InProgress
2019-05-08 00:27:25.331 Detail, Received: 0x01, 0x11, 0x00, 0x4a, 0x0a, 0x03, 0x0d, 0x0a, 0x04, 0x40, 0x03, 0x5e, 0x98, 0x9f, 0x55, 0x6c, 0x8a, 0x22, 0x25
2019-05-08 00:27:25.331 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2019-05-08 00:27:25.331 Info, ADD_NODE_STATUS_ADDING_SLAVE
2019-05-08 00:27:25.331 Info, Adding node ID 13 - Secure
2019-05-08 00:27:25.331 Detail, Notification: ControllerCommand - InProgress
2019-05-08 00:27:25.631 Detail, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x05, 0x0d, 0x00, 0xb0
2019-05-08 00:27:25.632 Detail,
2019-05-08 00:27:25.632 Info, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2019-05-08 00:27:25.632 Info, ADD_NODE_STATUS_PROTOCOL_DONE
2019-05-08 00:27:25.632 Detail, contrlr, Queuing (Command) Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2019-05-08 00:27:25.632 Detail, Notification: ControllerCommand - InProgress
2019-05-08 00:27:25.633 Detail,
2019-05-08 00:27:25.633 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x4a) - Add Node Stop: 0x01, 0x04, 0x00, 0x4a, 0x05, 0xb4
2019-05-08 00:27:25.686 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x06, 0x0d, 0x00, 0xb3
2019-05-08 00:27:25.686 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2019-05-08 00:27:25.686 Info, contrlr, ADD_NODE_STATUS_DONE
2019-05-08 00:27:25.686 Info, Node013, Network Key Not Set - Secure Option is required
2019-05-08 00:27:25.703 Info, Node013, Basic device class (0x04) - Routing Slave
2019-05-08 00:27:25.703 Info, Node013, Generic device Class (0x40) - Entry Control
2019-05-08 00:27:25.703 Info, Node013, Specific device class (0x03) - Secure Keypad Door Lock
2019-05-08 00:27:25.703 Warning, Node013, Security Command Class Cannot be Enabled - NetworkKey is not set
2019-05-08 00:27:25.703 Info, Node013, COMMAND_CLASS_BASIC will be mapped to COMMAND_CLASS_DOOR_LOCK
2019-05-08 00:27:25.704 Info, Node013, Mandatory Command Classes for Node 13:
2019-05-08 00:27:25.704 Info, Node013, COMMAND_CLASS_BASIC
2019-05-08 00:27:25.704 Info, Node013, COMMAND_CLASS_DOOR_LOCK
2019-05-08 00:27:25.704 Info, Node013, COMMAND_CLASS_USER_CODE
2019-05-08 00:27:25.704 Info, Node013, COMMAND_CLASS_MANUFACTURER_SPECIFIC
2019-05-08 00:27:25.704 Info, Node013, COMMAND_CLASS_VERSION
2019-05-08 00:27:25.704 Info, Node013, Mandatory Command Classes controlled by Node 13:
2019-05-08 00:27:25.704 Info, Node013, None
2019-05-08 00:27:25.705 Info, Node013, Optional command classes for node 13:
2019-05-08 00:27:25.705 Info, Node013, COMMAND_CLASS_ZWAVEPLUS_INFO
2019-05-08 00:27:25.705 Info, Node013, COMMAND_CLASS_SECURITY (Disabled - Network Key Not Set)
2019-05-08 00:27:25.705 Info, Node013, CommandClass 0x9f - NOT REQUIRED
2019-05-08 00:27:25.705 Info, Node013, CommandClass 0x55 - NOT REQUIRED
2019-05-08 00:27:25.705 Info, Node013, CommandClass 0x6c - NOT REQUIRED
2019-05-08 00:27:25.705 Info, Node013, CommandClass 0x8a - NOT REQUIRED
2019-05-08 00:27:25.705 Info, Node013, COMMAND_CLASS_APPLICATION_STATUS
2019-05-08 00:27:25.705 Detail, Node013, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2019-05-08 00:27:25.705 Detail, Node013, QueryStage_ProtocolInfo
2019-05-08 00:27:25.705 Detail, Node013, Queuing (Query) Get Node Protocol Info (Node=13): 0x01, 0x04, 0x00, 0x41, 0x0d, 0xb7
2019-05-08 00:27:25.706 Detail, Node013, Queuing (Query) Query Stage Complete (ProtocolInfo)
2019-05-08 00:27:25.706 Info, Node013, Initializing Node. New Node: true (true)
2019-05-08 00:27:25.706 Detail, Node006, Expected reply was received
2019-05-08 00:27:25.706 Detail, Node006, Message transaction complete
2019-05-08 00:27:25.706 Detail, contrlr, Removing current message
2019-05-08 00:27:25.706 Detail, Node013, Notification: NodeAdded
2019-05-08 00:27:25.711 Detail, Node013, Notification: NodeProtocolInfo
2019-05-08 00:27:25.714 Detail, Node013, Notification: ValueAdded
2019-05-08 00:27:25.723 Detail, Node013, Notification: ValueAdded
2019-05-08 00:27:25.726 Detail, Node013, Notification: ValueAdded
2019-05-08 00:27:25.729 Detail, Node013, Notification: ValueAdded
2019-05-08 00:27:25.731 Detail, Node013, Notification: ValueAdded
2019-05-08 00:27:25.734 Detail, Node013, Notification: ValueAdded
2019-05-08 00:27:25.736 Detail, Node013, Notification: ValueAdded
2019-05-08 00:27:25.739 Detail, Node013, Notification: ValueAdded
2019-05-08 00:27:25.741 Detail, Node013, Notification: ValueAdded
2019-05-08 00:27:25.743 Detail, Node013, Notification: ValueAdded
2019-05-08 00:27:25.746 Detail, Node013, Notification: ValueAdded
2019-05-08 00:27:25.748 Detail, Node013, Notification: ValueAdded
2019-05-08 00:27:25.751 Detail, Node013, Notification: ValueAdded
2019-05-08 00:27:25.753 Detail, Notification: ControllerCommand - Completed
2019-05-08 00:27:25.754 Detail,
2019-05-08 00:27:25.754 Info, Node013, Sending (Query) message (Callback ID=0x00, Expected Reply=0x41) - Get Node Protocol Info (Node=13): 0x01, 0x04, 0x00, 0x41, 0x0d, 0xb7
2019-05-08 00:27:25.757 Detail, Node013, Received: 0x01, 0x09, 0x01, 0x41, 0x53, 0xdc, 0x01, 0x04, 0x40, 0x03, 0x7f
2019-05-08 00:27:25.757 Info, Node013, Received reply to FUNC_ID_ZW_GET_NODE_PROTOCOL_INFO
2019-05-08 00:27:25.757 Info, Node013, Protocol Info for Node 13:
2019-05-08 00:27:25.757 Info, Node013, Listening = false
2019-05-08 00:27:25.757 Info, Node013, Frequent = true
2019-05-08 00:27:25.757 Info, Node013, Beaming = true
2019-05-08 00:27:25.757 Info, Node013, Routing = true
2019-05-08 00:27:25.757 Info, Node013, Max Baud Rate = 40000
2019-05-08 00:27:25.758 Info, Node013, Version = 4
2019-05-08 00:27:25.758 Info, Node013, Security = false
2019-05-08 00:27:25.758 Detail, Node220, Expected reply was received
2019-05-08 00:27:25.758 Detail, Node220, Message transaction complete
2019-05-08 00:27:25.758 Detail, Node013, Removing current message
2019-05-08 00:27:25.758 Detail, Node013, Query Stage Complete (ProtocolInfo)
2019-05-08 00:27:25.758 Detail, Node013, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2019-05-08 00:27:25.758 Detail, Node013, QueryStage_Probe
2019-05-08 00:27:25.758 Info, Node013, NoOperation::Set - Routing=true
2019-05-08 00:27:25.758 Detail, Node013, Queuing (NoOp) NoOperation_Set (Node=13): 0x01, 0x09, 0x00, 0x13, 0x0d, 0x02, 0x00, 0x00, 0x25, 0x0b, 0xc4
2019-05-08 00:27:25.759 Detail, Node013, Queuing (Query) Query Stage Complete (Probe)
2019-05-08 00:27:25.759 Info, Node013, Sending (NoOp) message (Callback ID=0x0b, Expected Reply=0x13) - NoOperation_Set (Node=13): 0x01, 0x09, 0x00, 0x13, 0x0d, 0x02, 0x00, 0x00, 0x25, 0x0b, 0xc4
2019-05-08 00:27:25.769 Detail, Node013, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-05-08 00:27:25.769 Detail, Node013, ZW_SEND_DATA delivered to Z-Wave stack
2019-05-08 00:27:26.917 Detail, Node013, Received: 0x01, 0x07, 0x00, 0x13, 0x0b, 0x00, 0x00, 0x73, 0x93
2019-05-08 00:27:26.917 Detail, Node013, ZW_SEND_DATA Request with callback ID 0x0b received (expected 0x0b)
2019-05-08 00:27:26.917 Info, Node013, Request RTT 1158 Average Request RTT 1158
2019-05-08 00:27:26.917 Detail, Expected callbackId was received
2019-05-08 00:27:26.918 Detail, Expected reply was received
2019-05-08 00:27:26.918 Detail, Message transaction complete
2019-05-08 00:27:26.918 Detail, Node013, Removing current message
2019-05-08 00:27:26.918 Detail, Node013, Notification: Notification - NoOperation
2019-05-08 00:27:26.920 Detail, Node013, Query Stage Complete (Probe)
2019-05-08 00:27:26.920 Detail, Node013, AdvanceQueries queryPending=0 queryRetries=0 queryStage=WakeUp live=1
2019-05-08 00:27:26.920 Detail, Node013, QueryStage_WakeUp
2019-05-08 00:27:26.920 Detail, Node013, QueryStage_ManufacturerSpecific1
2019-05-08 00:27:26.920 Detail, Node013, Checking for ManufacturerSpecific CC and Requesting values if present on this node
2019-05-08 00:27:26.921 Detail, Node013, Queuing (Query) ManufacturerSpecificCmd_Get (Node=13): 0x01, 0x09, 0x00, 0x13, 0x0d, 0x02, 0x72, 0x04, 0x25, 0x0c, 0xb5
2019-05-08 00:27:26.921 Detail, Node013, Queuing (Query) Query Stage Complete (ManufacturerSpecific1)
2019-05-08 00:27:26.921 Info, Node013, Sending (Query) message (Callback ID=0x0c, Expected Reply=0x04) - ManufacturerSpecificCmd_Get (Node=13): 0x01, 0x09, 0x00, 0x13, 0x0d, 0x02, 0x72, 0x04, 0x25, 0x0c, 0xb5
2019-05-08 00:27:26.930 Detail, Node013, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-05-08 00:27:26.930 Detail, Node013, ZW_SEND_DATA delivered to Z-Wave stack
2019-05-08 00:27:26.950 Detail, Node013, Received: 0x01, 0x07, 0x00, 0x13, 0x0c, 0x00, 0x00, 0x02, 0xe5
2019-05-08 00:27:26.950 Detail, Node013, ZW_SEND_DATA Request with callback ID 0x0c received (expected 0x0c)
2019-05-08 00:27:26.950 Info, Node013, Request RTT 29 Average Request RTT 593
2019-05-08 00:27:26.951 Detail, Expected callbackId was received
2019-05-08 00:27:36.922 Error, Node013, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-05-08 00:27:36.922 Detail, Node013, Removing current message
2019-05-08 00:27:36.922 Detail, Node013, Notification: Notification - TimeOut
2019-05-08 00:27:36.925 Detail, Node013, Query Stage Complete (ManufacturerSpecific1)
2019-05-08 00:27:36.925 Detail, Node013, AdvanceQueries queryPending=0 queryRetries=0 queryStage=NodeInfo live=1
2019-05-08 00:27:36.925 Detail, Node013, QueryStage_NodePlusInfo
2019-05-08 00:27:36.926 Detail, Node013, Queuing (Query) ZWavePlusInfoCmd_Get (Node=13): 0x01, 0x09, 0x00, 0x13, 0x0d, 0x02, 0x5e, 0x01, 0x25, 0x0d, 0x9d
2019-05-08 00:27:36.926 Detail, Node013, Queuing (Query) Query Stage Complete (NodePlusInfo)
2019-05-08 00:27:36.926 Info, Node013, Sending (Query) message (Callback ID=0x0d, Expected Reply=0x04) - ZWavePlusInfoCmd_Get (Node=13): 0x01, 0x09, 0x00, 0x13, 0x0d, 0x02, 0x5e, 0x01, 0x25, 0x0d, 0x9d
2019-05-08 00:27:36.935 Detail, Node013, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-05-08 00:27:36.935 Detail, Node013, ZW_SEND_DATA delivered to Z-Wave stack
2019-05-08 00:27:36.955 Detail, Node013, Received: 0x01, 0x07, 0x00, 0x13, 0x0d, 0x00, 0x00, 0x03, 0xe5
2019-05-08 00:27:36.955 Detail, Node013, ZW_SEND_DATA Request with callback ID 0x0d received (expected 0x0d)
2019-05-08 00:27:36.955 Info, Node013, Request RTT 29 Average Request RTT 311
2019-05-08 00:27:36.956 Detail, Expected callbackId was received
2019-05-08 00:27:36.982 Detail, Node013, Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x0d, 0x09, 0x5e, 0x02, 0x01, 0x07, 0x00, 0x03, 0x00, 0x03, 0x00, 0xaa
