Hi im a beginer. almost 3 week i tray to configure my home assistant bu i dnot understand what i do wrong. i cant pair xiaomi wall switch and home assistant.
please any idea ?
thank you
please any idea ?
thank you
i checked button again, its fine and work… hold down button and blue light flashes after 3-5 seconds later then I open the devices to join. time continues to decline…when I refresh zigbee2mqtt logs, nothing happens. i starting to think that button is not working properly or zigbee2mqtt device.
ZİGBEE2MQTT
“data_path”: “/share/zigbee2mqtt”,
“homeassistant”: true,
“permit_join”: false,
“mqtt_base_topic”: “zigbee2mqtt”,
“mqtt_server”: “mqtt://homeassistant”,
“serial_port”: “/dev/ttyACM0”,
“devices”: [],
“network_key”: []
MQTT
“logins”: [
“username”: “mqtt”,
“password”: “*********”
“anonymous”: false,
“customize”: {
“active”: false,
“folder”: “mosquitto”
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
To pair xiaomi sensors, you have to hold the pairing button and when the blue light flashes, you have to push continually on the pairing button to keep the sensor “awake”, otherwise the sensor will go in sleep mode directly.
same excacly i do what you say. push to button and hold,. has i say , noting happend
this is my configurator. Is there a setback in configurator ??
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: ******
longitude: ******
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: Europe/Istanbul
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url:
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Allow diagnosing system problems
system_health:
# Sensors
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
lovelace:
mode: yaml
panel_iframe:
configurator:
title: Configurator
icon: mdi:wrench
url: http://hassio.local:3218
logger:
default: critical
logs:
homeassistant.components: info
homeassistant.components.rfxtrx: debug
homeassistant.components.device_tracker: critical
homeassistant.components.camera: critical
mqtt:
broker: homeassistant # This will have to be your mqtt broker
discovery: true
input_boolean:
zigbee_permit_join:
name: Allow devices to join
initial: off
icon: mdi:cellphone-wireless
timer:
zigbee_permit_join:
name: Time remaining
duration: 600 # Updated this to the number of seconds you wish
- platform: mqtt
state_topic: "zigbee2mqtt/bridge/state"
icon: mdi:router-wireless
automation:
- id: enable_zigbee_join
alias: Enable Zigbee joining
hide_entity: true
platform: state
entity_id: input_boolean.zigbee_permit_join
to: 'on'
- service: mqtt.publish
topic: zigbee2mqtt/bridge/config/permit_join
payload: 'true'
- service: timer.start
entity_id: timer.zigbee_permit_join
- id: disable_zigbee_join
alias: Disable Zigbee joining
- entity_id: input_boolean.zigbee_permit_join
platform: state
to: 'off'
- data:
payload: 'false'
- data:
service: timer.cancel
hide_entity: true
- id: disable_zigbee_join_timer
alias: Disable Zigbee joining by timer
hide_entity: true
- platform: event
event_type: timer.finished
event_data:
payload: 'false'
- service: input_boolean.turn_off
Come on gusy. this issue is open to all kinds of comments.
Any idea ?
