Been working on this Integration (forked from original & expanded) to control BIQU or Big Tree Tech Panda Status - LED Print Progress & Status RGB LED light for Bambu Labs 3D Printers.
Integration allows you to control & select themes for you Panda Status or Panda Aura
Enables control of the light theme selection
Control Idle light as a light entity.
Follow printer light, switch is conditional available based on theme selection.
Been testing with Panda Aura for A1 / A1Mini but should be compatible with Panda Status P2 as well - keen on feedback if anyone has one.
Colour selection for static or breathing themes being worked on to be included in the next minor release.
Also includes some information about the printer
Came about that I like the h2D theme, but there is not option to follow printer light in original controls. This enable the use of H2D theme with an automation to track the printer and switch on the light based on printer status from BambuLab integration.
