Intermittent display anomaly on iPhone 7 following update to iOS Companion App 2.0. iPhone 8 does exhibit this issue. iOS 13.2.3, HA 102.2. Can be corrected by switching panels, but will return.
I believe this is a known issue. Do you see the same in Safari? It requires a fix in the frontend code
Just on Safari, and only on the iPhone 7.
Thanks Tom. I’ll do that.
