Hi All,
I’m pretty new to home assistant and I would like to integrate my 4 papago Thermometers into my Home assistant installation.
I’ve 4 Papago2 Thermometers, three with a single TH3 and one with 2xTH3. All of these 5 sensors are measuring Temperature, Humidity and DEW point.
These thermomenters have a custom software with an embedded web-server showing the temperature.
However, I set up the MQTT protocol to send messages to a broker and set up the MQTT integration into my homeassistant installation, but I cannot integrate into configuration.yaml in the correct form to grab temperature, humidity and dew point.
The MQTT messages are as follows:
{"dev": "Papago 2TH ETH","mac": "0080A3F7AA11","loc": "geotemp1","description": "LOG","log_index": 1445,"time": "10/28/2023 21:47:00","vals": [{"t": "temp","v": 3.5,"u": 0,"io": 1,"e": 0},{"t": "hum","v": 96.4,"u": 0,"io": 1,"e": 0},{"t": "dew","v": 2.9,"u": 0,"io": 1,"e": 0}]}
The same output JSON formatted is:
"loc": "geotemp1",
"log_index": 1446,
"time": "10/28/2023 21:48:00",
"vals": [
"t": "temp",
"v": 3.6,
"u": 0,
"io": 1,
"e": 0
"t": "hum",
"v": 96.8,
"u": 0,
"io": 1,
"e": 0
"t": "dew",
"v": 3.1,
"u": 0,
"io": 1,
"e": 0
my question is: how is the right syntax to insert this sensor in configuration.yaml ?
In addition, one of these thermometers has 2 sensors connected and the MQTT message shows 6 outputs, instead of 3. Below is an example:
"mac": "0080A3EAEAEA",
"loc": "geotemp5",
"log_index": 36636,
"time": "10/28/2023 21:51:00",
"vals": [
"t": "temp",
"v": 27.7,
"u": 0,
"io": 1,
"e": 0
"t": "hum",
"v": 33.6,
"u": 0,
"io": 1,
"e": 0
"t": "dew",
"v": 10.2,
"u": 0,
"io": 1,
"e": 0
"t": "temp",
"v": 17.5,
"u": 0,
"io": 2,
"e": 0
"t": "hum",
"v": 64.1,
"u": 0,
"io": 2,
"e": 0
"t": "dew",
"v": 10.6,
"u": 0,
"io": 2,
"e": 0
Thanks in advance and best regards.
Digitalchild
