This simple blueprint allows you to synchronize a Quido binary sensor input with a Quido switch output.
How it works:
Uses 1 binary sensor input that controls 1 switch. When the input turns ON, the switch turns ON. When the input turns OFF, the switch turns OFF.
Blueprint Code
blueprint:
name: Papouch simple blueprint for Quido
description: Turn the switch ON when input returns ON
domain: automation
input:
binary_sensor:
name: Binary sensor of a Quido
description: Use a input of a Quido
selector:
entity:
domain: binary_sensor
switch:
name: Switch of a Quido
description: Use a output of a Quido
selector:
entity:
domain: switch
triggers:
- trigger: state
entity_id: !input binary_sensor
actions:
- action: >
{% if trigger.to_state.state == "on" %}
switch.turn_on
{% else %}
switch.turn_off
{% endif %}
entity_id: !input switch
