Par16 bulb 3UT1 base?
I’m not exactly sure what bulbs these are but hopefully someone can tell me if there is an RGB bulb that works with home assistant?
The only ones I could find with a PAR16S format are infra red controlled. So not a good option even if you use an IR controller hooked up to HA as it can not tell what state the bulb is in.
Time to change your light sockets?
Yeah I hear ya…just sad cause it’s a new house and these things are everywhere…
Reading more on this…I could use an MR16 type bulb which is the same 2" size as a par16 with the same E26 base and that should work?
MR16 have prongs instead of an Edison Screw base. And they are usually 12V.
